New Proccessor Decision
- Legit User
I'm looking for a new processor for my rather old PC since at the moment I'm running on two 3.06 ghz Pentium 4's.
I know a little bit about computers, but I'm not expert. So far I've narrowed it down to 3 processors.
The Cheaper Option
Dual Core
Quad Core
Simply, i wanna know which is best overall and why?
Also, if the more expensive ones are worth the extra cash. Thanks for any help with this!
The Cheaper Option
Dual Core
Quad Core
- Apoptosis
- Site Admin
Re: New Proccessor Decision
what will the primary purpose of this computer be and would you be willing to overclock it?
Just confirming... You have checked that these are compatible with your current motherboard, right? Just because they both use the same socket (LGA775) doesn't mean you can do a drop-in replacement.
unRAID Server
unRAID Server
- Legit User
Mostly games and media and yes, I'm willing to overclock it.
As for compatibility, this is my motherboard. The sockets are the same, but double checking, it seems the processor isn't listed under CPU support...which means its not compatible and i need a new motherboard too.
- dicecca112
- Site Admin
Motherboard is a 915P chipset, read 4 years old, and none of those CPUs are compatible. The motherboard is not replaceable because it uses proprietary mounting and cooling. It was a specially made Gigabyte board for Companies like Dell, Packard Bell and HP
Your best option may be to sell the old system and build yourself a new one. I understand that the people from LR are highly qualified to give you solid advice on that build.
Getting away from locked bios' , proprietary components, and other company imposed limitations is a very good reason for building your own system. It's a move I will never regret.
That's one thing I've come to hate about OEM PC's. They've got lots of proprietary stuff and you're very limited in terms of expansion. Nowadays, even if I could spend less money buying OEM, I still build my own.
unRAID Server
unRAID Server
- Legit User
So basically i cant upgrade this computer, and would be better off making a new one from scratch?
- stopthekilling77
Precisely, and you'll be able to build something much better doller-for-dollarUltima9999 wrote:So basically i cant upgrade this computer, and would be better off making a new one from scratch?
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
- Legit User
Alright then, I've always wanted to build my own computer anyway.
Anyone got any ideas along the lines of those processors? Or not, any suggestions would be appreciated lol
I don't expect anyone to do my grunt work, but anything off the top of your head would be helpful, thanks.
To get some good suggestions two things will be helpful...your budget and what you plan to use the computer for. A computer built for gaming will differ greatly in components and price compared to a computer just to browse the internet or word processing.
- Legit User
I am planning to use it as a gaming pc and as for budget...nothing crazy, having little money is an occupational hazard of being a student but i am willing to pay a decent amount if its good value and will last me a while.ibleet wrote:To get some good suggestions two things will be helpful...your budget and what you plan to use the computer for. A computer built for gaming will differ greatly in components and price compared to a computer just to browse the internet or word processing.
Looking at the processors above, i guess you could base my budget around that.
The E8400 is a great CPU for a mid-ranged gaming set-up. It should give your plenty of power for any of the games out there right now. Just make sure you pick up a decent graphics card as that will likely hold you back more in game than your CPU.
CPU: Intel Core i5-2500k
Mobo: Asus Z77 Gene
GPU: GTX 470
RAM: 2X4gb G.Skill 1600
OS SDD: Kingston 120 gb SSD
Game SSD: Kingston 128 gb SSD
Storage: Hitachi 1Tb, Intel 80 gb SSD
PSU: Corsair AX 850w
Case: Silverstone FT-03
Mobo: Asus Z77 Gene
GPU: GTX 470
