My benching setup - What a mess!
kenc51
Post by kenc51 »
The pic is bad quality for some reason, it happened after I resized it, but you get the message
This is my current bench setup. I stripped down the rig earlier this week.
This should be a PSA for how NOT to do it ;)
& this is how it should be done!
Bio-Hazard
Re: My benching setup - What a mess!
Post by Bio-Hazard »
I'd say that you have your work cut out for yourself getting that mess all straighten up............. :shock:
But I have faith that you'll get it done.
dicecca112
Post by dicecca112 »
dude its called a can of compressed air, clean those fans man
Major_A
Post by Major_A »
I've seen worse, it was called the back of my desk. All you need is to dust that beast and use a lot of zip ties/cable ties.
DMB2000uk
Post by DMB2000uk »
dicecca112 wrote:dude its called a can of compressed air, clean those fans man
If you are talking about the fan on his 8800GTS, isnt that the one he bought just couple of weeks back? So its probably just the fan colour/bad pic making it look dusty :ANAL:
Well if you had a torture bench like LR does, then I'm sure that you could tidy the cables easier :P
Dan
Image (<- Clickable)
dicecca112
nope the case fans on the back
DMB2000uk
Post by DMB2000uk »
dicecca112 wrote:nope the case fans on the back
>_< I was looking for dust on ken's bench, not nate's or whoever's the torture rack was :rolleyes:
Dan
kenc51
Post by kenc51 »
Dan
The torture rack was from pastorjay's mobo review, hence the LR watermark
Methious
Post by Methious »
Hey don't feel bad up til last month I had my work bench rig hanging on the wall on a piece of plywood, covered in a plexi shroud. Local tech school bought it and I switched to a full tower setup.
Seems like every time I get all the cables strapped in just right a new part comes through the door and I gotta re-strap.
Bio-Hazard
Cleanliness is next to godliness, you gotta keep those systems clean if you want them to take care of you. ............. :mrgreen:
kenc51
Post by kenc51 »
No-one noticed the dead gfx card in the back, it was an X1900XTX :cry:
DMB2000uk
Post by DMB2000uk »
kenc51 wrote:No-one noticed the dead gfx card in the back, it was an X1900XTX :cry:
It's been swallowed by the mess of wires, and the low quality pic makes it ahrd to pick out details :ANAL:
Dan
skier
Post by skier »
it must be playing hide and seek with the camera :) , i cant see it at all, i can barely make out the HDD
is that setup like, half in a tower and half on the floor?? because it looks like i can see the expansion slots in the upper left corner of the pic
-Austin
Screamin' BCLK: Image
