The Phantom Lord (Thermaltake Armor Modded Water Cool)
Re: The Phantom Lord (Thermaltake Armor Modded Water Cool)
yeah, please do give details, it'll help alot
I edited my last post. I will get in trouble if I double or triple my posts. I will show you what my firewall is showing.
Risk category: Virus
Overall Risk Impact: High
Performance: High
Privacy: High
Removal: High
Stealth: High
Click for more information about this risk : Trojan Horse
Action taken: Blocked
Affected Areas: c:\documents and settings\victor\local settings\temporary internet files\content.ie5\1iin9xly\x7b[1].xml
It's called Bloodhound. Exploit 196
I have 2 firewalls, one has encryption and the other is a security suite. I hardly ever have this issue. Just thought that you guys should know about what I am dealing with.
Performance: High
Privacy: High
Removal: High
Stealth: High
- stopthekilling77
Did you send this info to the people over at imageshack?
Cyberpower special rig
ASUS Prime 450M-A
Ryzen 5 3600 stock
CM Hyper 212 EVO push/pull
24GB DDR4 3000 (soon to be 32GB)
AMD RX 580 8GB
Samsung 970 EVO Plus 500GB NVMe SSD
Lexar 256GB SSD
6GB Seagate hdd
Stock PSU (will upgrade)
ASUS VE278 27" monitor, Samsung Vizio V435-G0 42" 4K TV
Logitech Z533 2.1 Speakers, G935 7.1 headset
MS LXM-00001 Ergonomic kbd
Razer Deathadder Elite, XBOX One wireless controller
I've come a long way from that original Core2Duo build y'all!
ASUS Prime 450M-A
Ryzen 5 3600 stock
AMD RX 580 8GB
Lexar 256GB SSD
6GB Seagate hdd
- martini161
- Mr Awesome
try firefox see if it helps
- Skippman
Firefox is some how going to prevent you from getting a virus?
- Alathald
It'll help prevent the ones that IE5 is vulnerable to.
vbironchef wrote:Affected Areas: c:\documents and settings\victor\local settings\temporary internet files\content.ie5\1iin9xly\x7b[1].xml
- Skippman
Alathald wrote:It'll help prevent the ones that IE5 is vulnerable to.vbironchef wrote:Affected Areas: c:\documents and settings\victor\local settings\temporary internet files\content.ie5\1iin9xly\x7b[1].xml
I guess my point was it shouldn't matter which browser you're using, there shouldn't be a virus in the first place.
- Alathald
Yeah you're absolutely right there should be no virus in the image and there is not...vb this is probably a preexisting virus on your system, after a bit of looking I found out that "Bloodhound.Exploit.196 is a heuristic detection for files attempting to exploit the Adobe Acrobat and Reader Multiple Arbitrary Code Execution and Security Vulnerabilities." It has nothing to do with imageshack, just a random false positive.
People, don't be afraid to check out martini's rig, his pics are safe (well, from virii any way)
- Skippman
And they look sweet!
<that's why people need to use FoxIT Reader!>
- Sporg
Darn that Martini with his sexy black interior!
~Bertrand Russell
~Bertrand Russell
Hey Marty, what's that hand held tool called that you used to cut out those holes?
(second picture on this post)
Dan
Dan
- martini161
- Mr Awesome
ratcheting knock out tool?
think the slang term is slug buster
Quit being an attention whore and bumping this thread
Dan
Dan
- martini161
- Mr Awesome
did you ever find that tool you was lookni for?DMB2000uk wrote:Quit being an attention whore and bumping this thread
Dan
Decided to bodge it with a dremel.
Dan
Dan
