How To: Mount a fan in extra 5 1/2" bays (Done)
martini161
Mr Awesome
Mr Awesome
Re: How To: Mount a fan in extra 5 1/2" bays (Done)
Post by martini161 » Sun Feb 24, 2008 7:24 am
yeah i know. thats all done with some crappy camera, it would never auto focus, and you couldnt manual focus it either, so i cant really help it :rolleyes:
Methious
Post by Methious » Sun Feb 24, 2008 10:18 am
My HP camera seems to do that when I don't use the flash.
martini161
Mr Awesome
Mr Awesome
Post by martini161 » Sun Feb 24, 2008 1:18 pm
Methious wrote:ThermalTake Armor full tower case 250mm side fan? If it is how loud are the interior 120mm fans that came stock? Been looking at that case.
the case fans are very quiet as far as i can tell (droned out by the 45+db fan on the radiator and the 8800gt's fan) you wont really need a fan controller, they are quiet up to the highest steed. i think the specs say something like 20db another nice thing about them is they come with a 3pin connector but only the rpm sensor cable is actually attached to it.
but personally, i would not recomend it except for something like a server. the hdd cages that go on the top are usless to me, but i may use them if i get a 2x120mm rad to mount to the front of my case. the only problem is, im gonna have to rig up some elaborate mounting scheme, because the whole front panel is nothing but 5 1/2" bays ](*,) but if you dont use a disk drive, and you buy 3 of these http://www.newegg.com/Product/Product.a ... 6811999169 you can fit 17 hard drives in there :shock: thats why i recommend it to people as a server case
Bio-Hazard
Post by Bio-Hazard » Sun Feb 24, 2008 5:47 pm
There are several companies that make brackets to mount radiators in 5.25 bays, they are pretty much universal and will fit just about anf radiator or case.
Lian-Li ang Aqua-Computer come to mind at first thought.............. :mrgreen:
http://www.performance-pcs.com/catalog/ ... s_id=21047
http://www.sharkacomputers.com/aqco5drbayra.html
Pretty easy to make your own as well out of a little "L" channel aluminum ................ 8)
martini161
Mr Awesome
Mr Awesome
Post by martini161 » Sun Feb 24, 2008 8:07 pm
thanks bio ive been lookin all over for those. of course you knew where t find them immediatly
Bio-Hazard
Post by Bio-Hazard » Sun Feb 24, 2008 11:33 pm
NP...............I try to keep up a little with what's going on.................. :mrgreen:
But honestly I'd try and make them, it's one heck of a lot cheaper, but you do need to have fairly good dremel skills.
martini161
Mr Awesome
Mr Awesome
Post by martini161 » Mon Feb 25, 2008 2:50 pm
Bio-Hazard wrote:NP...............I try to keep up a little with what's going on.................. :mrgreen:
which i dont have :lol: or any scrap aluminum
