After the WAR
Here you can find out about our Folding Team! Our goal: to understand protein folding, protein aggregation, and related diseases
shamrok3
Re: After the WAR
Post by shamrok3 »
If you are running command line folding, run config, if you are running system tray, right click and select configure. (For Systray) Go to Advanced, there is a slider for CPU usage percentage, reduce it. (For Command Line) Select yes for configure advanced options and there should be a question about CPU usage percentage, change the amount to something like 70-80%.
Multiple Exclamation marks - The first sign of an unsound mind.
Rig: Intel 3930K, Noctua U12P-SE2 , ASUS P9X79, 16GB RAM, 60GB OCZ Vertex 3, 2x3TB Seagate (RAID 0), 1TB Samsung F3, EVGA GTX760, CM 650 Watt PSU
NZXT HU002 Case, LG Blu-Ray Writer/Combo
21.5" BenQ E2200HD @ 1920x1080, Razer Lachesis/Lycosa/Sennheiser HD558, Windows 8.1 Pro 64 Bit
kylepaddock
Re: After the WAR
Post by kylepaddock »
i have my GPU folding. i am moving to win7 so its on and off.
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
Ebay is: horizonlongtails it is 100%!!!
Sapientun
Legit Fanatic
Legit Fanatic
Re: After the WAR
Post by Sapientun »
shamrok3 wrote:If you are running command line folding, run config, if you are running system tray, right click and select configure. (For Systray) Go to Advanced, there is a slider for CPU usage percentage, reduce it. (For Command Line) Select yes for configure advanced options and there should be a question about CPU usage percentage, change the amount to something like 70-80%.
I thought that doesn't after affect GPU usage? Afterall, it's called CPU usage percentage...
shamrok3
Re: After the WAR
Post by shamrok3 »
I'm pretty sure it still reduces your GPU usage.
kylepaddock
Re: After the WAR
is that info how to get me smp clients sh show up in my sidebar thing?
shamrok3
Re: After the WAR
Post by shamrok3 »
No, as far as I know, SMP folding is only command line. You can run multiple single core folding clients, which does show up as a taskbar icon.
kylepaddock
Re: After the WAR
shamrok3 wrote:No, as far as I know, SMP folding is only command line. You can run multiple single core folding clients, which does show up as a taskbar icon.
i an doing the single core ones and 4 of them, i cant get it to use 4 cores in one.
shamrok3
Re: After the WAR
Post by shamrok3 »
You might be able to set it as SMP, but then it's so much faster (especially on AMD) to run Linux VM. Try going into the config, and under additional (client?) parameters type in -smp 4, or if you have an i7 with virtualization/hyper-threading (whichever one gives you virtual strings) type in -smp 8, where the number at the end is how many cores you have. (I haven't tried this so, don't count on it, I just use Linux VM folding and ignore the minimized window)
kylepaddock
Re: After the WAR
i have vmware downloaded, i just dont know how to use it, i have a AMD phenom
Wifuzzy
Re: After the WAR
Post by Wifuzzy »
I won one of the 965 X4's...what would that get me for PPD? I was originally gonna put in in my HTPC, but that would need a motherboard change and would create Windows 7 activation issues. Is it worth folding on it or should I just stick to my GPUs?
shamrok3
Re: After the WAR
Post by shamrok3 »
For kyle: Geokilla gave me this link a couple of weeks ago http://www.evga.com/forums/tm.aspx?m=4464 it has a pretty good tutorial on getting VM folding running.
For Fuzzy: My PII 940 @ 3.41GHz (Most of the time) gives around 850-1000PPD. I'm not entirely sure on this figure as I fold on my Desktop CPU, GPU, my Laptop CPU and GPU and my PS3, but I'm pretty sure most of my pts come from my Desktop CPU as the Laptop CPU finishes a WU only around every 3 or so days, the Desktop GPU gives around ~500PPD and same on Laptop GPU. As far as I know the PS3 has been folding for a week now and has only got ~250pts. I sorta feel like my PPD is a bit low for the hardware I'm running, but that's what I'm getting.
kylepaddock
Re: After the WAR
it says bigdav is for 8 core systems,
spitter
Re: After the WAR
Post by spitter »
Wifuzzy wrote:I won one of the 965 X4's...what would that get me for PPD? I was originally gonna put in in my HTPC, but that would need a motherboard change and would create Windows 7 activation issues. Is it worth folding on it or should I just stick to my GPUs?
You can get 4k-5k ppd out of it if you use smp notfred!!
http://forums.legitreviews.com/about24341.html
kylepaddock
Re: After the WAR
if u dont want it, i got a use.
kylepaddock
Re: After the WAR
i get this error now,
kylepaddock
Re: After the WAR
fixed that problem and now in the login screen i cant select amd and it goes to intel?
shamrok3
Re: After the WAR
Post by shamrok3 »
Click in the screen to send keystrokes to the VM. Restart the VM and quickly press in the screen and press down, then enter.
kylepaddock
Re: After the WAR
ok, thanks, is working now, how to I get fahmon to show it?
geokilla
Re: After the WAR
Post by geokilla »
Doesn't matter if you use the Intel or AMD build. In fact, I seem to get more PPD with the Intel build.
Gigabyte Z77X-UD5H F14 BIOS
ASUS GTX 460 768MB @ 800/1950
Corsair AX750
Crucial M4 128GB
Western Digital Black 1TB
Cooler Master Hyper 212+ EVO
BenQ E2420HD
I AM CANADIAN!
kylepaddock
Re: After the WAR
it looks like it says 17 hrs, and looks like a single core unit,250K
