OCZ Technology Showcases Cutting-Edge SSD Technology at CES
Bwall
Post by Bwall »
OCZ has SSD Fever! From SATA, SAS, and even USB 3.0, OCZ looks to have an SSD solution for virtually every drive market.
San Jose, Calif.—January 6, 2010—OCZ Technology Group, Inc., a worldwide leader in innovative, ultra-high performance
and high reliability memory and flash-based storage as an alternative to hard disk drives, plans to unveil an array of next
generation solid state drives (SSDs) along with other premium hardware at the International Consumer Electronics Show
in Las Vegas, Nevada. With its finger on the pulse of emerging and booming markets, OCZ’s impending line of SSDs are
designed to optimize entire businesses as well as the computing experiences of everyday consumers.
“This CES we continue to build on our lineup of SSD solutions designed for enterprise class applications,” commented
Ryan Petersen, CEO of the OCZ Technology Group. “In addition to our robust lineup of 2.5” solid state drives we will be
launching new drives with interfaces that include SAS and PCI-E which make it easier than ever for enterprise clients to
replace expensive-to-maintain, traditional storage media with a higher performing and more reliable solution.”
OCZ storage products not only continue to revolutionize performance, durability, and power efficiency compared to
traditional hard drives, but address a wide range of applications from enterprise-class data management to personal
notebooks. By continuously enhancing the technology and broadening partnerships, OCZ is on a path to make SSDs the
superior choice over HDDs for OEM-clients, business storage infrastructures, and the average end-user who all place a
www. o c z t e c h n o l o g y. c om premium on performance, low power consumption, and total cost of ownership (TCO).
SATA II 2.5” SSDs
OCZ has paved the way in consumer solid state drives, addressing the demand for performance and affordability. As
OCZ’s next SSD generation, the Vertex 2 Series pushes the envelope even further and provides a truly viable MLC-based
enterprise storage option. The Vertex 2 line features an innovative, higher performing architecture designed to serve the
needs of the entire range of computing environments.
USB 3.0 SSD
In addition to internal storage solutions, OCZ will demonstrate the ground-breaking performance of the highly-anticipated
USB 3.0 interface with their ultra-slim portable SSD. Geared toward the early-adopting enthusiast, the OCZ USB 3.0 SSD
sets the bar early for high performance storage devices.
SAS and PCI-E SSDs
OCZ has a proven track record in the design and manufacture of 2.5 inch solid state drives and is in a unique position to
be able to do the same with PCI-Express and Serial-attached SCSI (SAS) SSDs in the enterprise space. With a 2nd
generation PCI-Express design and 1st generation SAS SSD, customers can reliably enable the usage of lower cost, MLCbased
SSDs for intensive data processing with these drop-in solutions and gain exceptional bandwidth, while scaling down
necessary rack space.
Gaming and Enthusiast Hardware
OCZ remains committed to the gaming and enthusiast industries and other sectors of the market where stability and
performance are of utmost importance. OCZ’s latest DDR3 memory solutions provide world-class speeds at low voltages
requirements, while the new Fatal1ty 750W and PC Power Silencer mkII power supplies offer unwavering stability to
support a wealth of power-hungry components and push cutting-edge systems to the limit.
shamrok3
Re: OCZ Technology Showcases Cutting-Edge SSD Technology at CES
Post by shamrok3 »
Isn't OCZ a fairly SSD-oriented company? Apart from memory, what else do they make?
Multiple Exclamation marks - The first sign of an unsound mind.
Rig: Intel 3930K, Noctua U12P-SE2 , ASUS P9X79, 16GB RAM, 60GB OCZ Vertex 3, 2x3TB Seagate (RAID 0), 1TB Samsung F3, EVGA GTX760, CM 650 Watt PSU
NZXT HU002 Case, LG Blu-Ray Writer/Combo
21.5" BenQ E2200HD @ 1920x1080, Razer Lachesis/Lycosa/Sennheiser HD558, Windows 8.1 Pro 64 Bit
DMB2000uk
Post by DMB2000uk »
Power supplies, Thermal Paste, CPU Coolers, Mice, Keyboards...
So not really :P
Dan
*Edit* Though they probably make most of their money off of memory based products :P
Image (<- Clickable)
