EVGA GTX 400 Series High-Flow Exhaust Bracket
EVGA has started to sell their GTX 400 Series High-Flow Exhaust Bracket that is said to lower GPU temperatures by up to 5C.
Compatible with GTX 480, 470, & 465
The MSRP is just $9.99 and is shipped free! Grab it here - http://www.evga.com/products/moreInfo.a ... -00-000171
InspectahACE
Re: EVGA GTX 400 Series High-Flow Exhaust Bracket
Post by InspectahACE »
Is this only for EVGA or could I put these on my Galaxy branded cards as well?..stupid question but you never know these days
Should fit all cards based off the NVIDIA reference design.
werty316
Post by werty316 »
5C my you know what; a high flow bracket isn't gonna help reduce the heat generated by the GF100 chip; a better cooling system is need; maybe something similar to Sappire's Vapor-x chamber HSF.
werty316 wrote:5C my you know what; a high flow bracket isn't gonna help reduce the heat generated by the GF100 chip; a better cooling system is need; maybe something similar to Sappire's Vapor-x chamber HSF.
My thoughts exactly and I have one on the way to find out first hand.
gwolfman
Post by gwolfman »
Sounds interesting. Can't wait to see it reviewed.
skier
Post by skier »
same as on the lower end axle cards, but not much air actually goes through it lol
back on the GT 240, silly arctic cooling hs/f found on tons of budget cards
-Austin
Screamin' BCLK: Image
The EVGA bracket has slots around the DVI ports and next to the mini-HDMI port.
Also the EVGA has 11 holes versus the 10 in that one (not like 1 is going to be a huge difference)
DJ Tucker
Post by DJ Tucker »
the bracket won't work and as werty316 wrote yep just better cooling :shock:
MSI Z590 Gaming Edge Wifi
Corsair XR5 240mm x2 & 360mm
Corsair HX1000i
Lian Li O11D
InspectahACE
I say let Nate tell us the verdict before making any judgments.
Rollo
Legit User
Legit User
Post by Rollo »
InspectahACE wrote:I say let Nate tell us the verdict before making any judgments.
I have two on the way for my 480s.
I've found that case air flow can make a significant difference in the GTX series temps. By switching from a CoolerMaster Cosmos 1010 with a 120mm side fan to a CoolerMaster HAF932 my Metro2033 temps went from 92-94C down to 84-86C on the top card.
If these brackets work as advertised, I should get down to the 79-81C range. Not bad for $159. total- not much more than the cost of one waterblock and I don't have the hassles/added expense of water.
If they don't work, or can't give me more than the case already has, I'm still pretty happy with running the 480s at full load in the mid 80s. My philosophy on high end graphics has always been that you build a system around the properties of the graphics, not settle for lesser graphics.
NVIDIA Focus Group Member
NVIDIA Focus Group Members receive free software and/or hardware from NVIDIA from time to time to facilitate the evaluation of NVIDIA products. However, the opinions expressed are solely those of the Members.
werty316
Post by werty316 »
They have a deal going on for a free* high flow GTX 470/480 bracket : http://www.evga.com/articles/00556/
(*When they say free, you pay $4.95 for shipping)
InspectahACE
werty316 wrote:They have a deal going on for a free* high flow GTX 470/480 bracket : http://www.evga.com/articles/00556/
not a bad deal, if you have an EVGA card
Just got mine today... Will start testing it real quick to see what it does.
Also the USPS print out on my box shows it took $2.07 to get it from zip 92821 California to Missouri in a 6x6x3 box.
