AMD Radeon HD 6870 Reference Design Video Card Pictured
Here it is, the AMD Radeon HD 6870, all dressed up to go to work. There has been quite some speculation surrounding the naming scheme AMD is going to adopt with the HD 6000 series, but fresh information suggestively lays some of that to rest. Firstly, Radeon HD 6800 series is built around the "Barts" GPU, not "Cayman". Barts is a new performance GPU, though isn't the highest-end single GPU from AMD (which is reserved for Cayman). Barts "XT" is Radeon HD 6870, and Barts "Pro" is HD 6850. Pictured below is the HD 6870. At a purely subjective glance, the HD 6870 reference design card seems to be as long as the HD 5850 reference.
The new Radeon logo has been Photoshopped on to the fan, so the products in market will definitely do away with the older ATI logo. The rear panel resembles that of the Radeon HD 5800 series, except that the exhaust grille seems slightly wider, there are two DVI-I connectors, one standard HDMI, and two mini DisplayPort connectors for a change. The connector output sharing scheme isn't known right now, it could be 3 or 4 head Eyefinity, or all-out 5 head Eyefinity, a yet to be detailed "Eyespeed" feature is mentioned. We will definitely know more about this card in the weeks to come.
source
skier
Re: AMD Radeon HD 6870 Reference Design Video Card Pictured
Post by skier »
you would think they would have 'done away with it' on the prototype to begin with, not like it's a new development :lol:
and i like how the screws on the backplate aren't straight either, reminds me too much of early Fermi...
/believe it when it launches
-Austin
Screamin' BCLK: Image
Sttm
Post by Sttm »
What is AMD thinking with this naming. So the 5770 replacement is going to be called 6870, while most likely being slower then the 5870. Why do that unless they want to intentionally misdirect customers.
Core i7 2600k/ ASUS P8Z68-V Z68/ 8gb Corsair Vengeance 1600 Blue/ EVGA Geforce GTX 560ti Maximum Graphics Edition/Windows 7/Antec 300/Antec 650w/LG Blu Combo/Hp 27inch 2710M/Samsung P2770HD
"I think sharing is overrated...and helping others. And what's all this crap I've been hearing about tolerance?"
skier
Post by skier »
Sttm wrote:So the 5770 replacement is going to be called 6870
didnt notice that
so 6970 cayman would be top (as 5870 now)- then they would have to bring back the X2 suffix (6970 X2). unless 6970 cayman is actually the 6870 X2, just designated as another die
-Austin
hark
Post by hark »
The little wave is a neat touch. Not liking the naming scheme they have going on, though.
stopthekilling77
Post by stopthekilling77 »
The naming scheme is terrible! I just hope that my PSU will be enough for whatever the top non dual-gpu card is named.
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
One week to go until the card's launch and a Radeon HD 6870 branded by ex-Nvidia partner XFX has popped up online via two high-resolution pictures. The card in question is powered by one Barts 40nm GPU, has DirectX 11 support and is supposed to be faster than the 1GB GeForce GTX 460.
XFX's card takes up two slots, and requires additional power via two 6pin PCIe connectors, has 2-way CrossFire support, a 256-bit memory interface, 1GB of GDDR5 VRAM clocked at 5000 MHz, and two DVI, one HDMI 1.4 and two mini DisplayPort 1.2 outputs. The Radeon HD 6870 should be price in the $200 - $300 range.
Source
Aniki
Legit User
Legit User
Post by Aniki »
Looks like it's gonna be an awesome card. 5 display connectors on a video card is insane.
Aniki wrote:Looks like it's gonna be an awesome card. 5 display connectors on a video card is insane.
yeah, but remember the card can support 6 monitors with daisy chaining off the pair of mini-DisplayPort connectors.
