ZOTAC combines LGA115 processors with mini-ITX form factor
bubba
Staff Writer
Staff Writer
Post by bubba »
ZOTAC® Kicks Off CES with Miniature 2nd Generation Intel® Core™ Platform
ZOTAC® H67-ITX WiFi combines LGA1155 socket processors with mini-ITX form factor
HONG KONG – Jan. 5, 2011 – ZOTAC® International, a leading innovator and the world’s largest channel manufacturer of graphics cards, today kicks off the 2011 Consumer Electronics Show with the H67-ITX WiFi – a miniature 2nd Generation Intel® Core™ platform. The ZOTAC® H67-ITX WiFi takes the mini-ITX form factor to new heights of performance, energy-efficiency and integrated graphics capabilities.
Equipped with the Intel® H67 Express chipset, the ZOTAC® H67-ITX WiFi supports the latest LGA1155 2nd Generation Intel® Core™ family processors including 2000 series Core™ i3, i5 and i7 processors. The ZOTAC® H67-ITX WiFi goes beyond the capabilities of the 2nd Generation Intel® Core™ platform and accommodates processors up to 130-watt TDP – above the 95-watts required by the fastest Intel® Core™ i7 processor – for additional overclocking headroom that appeals to the most demanding enthusiasts.
“ZOTAC® has a broad line-up of mini-ITX platforms and continues to push the limits of what is possible in such a small form factor,” said Carsten Berger, marketing director, ZOTAC® International. “The H67-ITX WiFi is our new flagship and the perfect scalable platform that lets users select their ideal level of performance needs – whether it is dual or quad-core processing, integrated Intel® HD Graphics 2000/3000 or a high-performance ZOTAC® GeForce® series graphics card – the H67-ITX WiFi supports it all.”
Integrated Intel® HD Graphics 2000/3000 is supported on the ZOTAC® H67-ITX WiFi via DisplayPort, HDMI, DVI-I and VGA [with the included adapter] for connectivity with the latest digital and legacy analogue displays.
Intel® HD Graphics 2000/3000 with InTru™ 3D technology is capable of decoding two simultaneous 1080p video streams for flawless Blu-ray 3D playback when connecting the ZOTAC® H67-ITX WiFi to a compatible HDMI 1.4a display. Accompanying Dolby® TrueHD and DTS-HD™ Master Audio formats on Blu-ray and Blu-ray 3D movies can be sent directly to home theatre receivers in its raw state from the ZOTAC® H67-ITX WiFi for crystal clear surround sound audio that delivers an outstanding digital entertainment experience pleasing to your eyes and ears.
Expansion is plentiful with the ZOTAC® H67-ITX WiFi, including 2 SATA 6.0 Gb/s, 4 SATA 3.0 Gb/s with support for RAID 0, 1, 0+1 and 5, eSATA, up to 4 USB 3.0 ports and a PCI Express x16 expansion slot. On-board 802.11n WiFi and Gigabit Ethernet deliver network transfers up to 300 Mb/s wirelessly or 1000 Mb/s wired for lightning-fast network connectivity.
It’s time to play with the ZOTAC® H67-ITX WiFi.
General details
• ZOTAC® Kicks Off CES with Miniature 2nd Generation Intel® Core™ Platform
• H67-ITX WiFi platform
• Intel® H67 Express chipset
• Ready for 2000 Series Intel® Core™ i3, i5 and i7 processors
• LGA1155 socket compatible
• Support processors up to 130-watt TDP
• 2 x DDR3-1333 slots (dual-channel)
• Support up to 16GB memory
• Intel® HD Graphics 2000/3000 ready
• DisplayPort, HDMI, DVI-I & VGA (with included adapter) outputs
• PCI Express x16 expansion
• 2 SATA 6.0 Gb/s
• 4 SATA 3.0 Gb/s w/ RAID 0, 1, 0+1 & 5
• 4 USB 3.0 ports (2 on back panel, 2 via pin header/included bracket)
• 8 USB 2.0 ports (4 on back panel, 4 via pin headers)
• Hardware accelerated Blu-ray 3D playback ready
• Dolby® TrueHD & DTS-HD™ Master Audio bitstream capable
• Digital S/PDIF output (optical)
• 8-channel high-definition audio
• Microsoft® DirectX® 10 compliant
• Onboard 802.11n WiFi (300 Mb/s)
• Gigabit Ethernet
• Mini-ITX form factor
Specifications:
Product Name: H67-ITX WiFi
Chipset: Intel® H67 Express
South Bridge: NA (single-chip solution)
GPU: Intel® HD Graphics 2000/3000 ready
CPU Compatibility: 2nd Generation Intel® Core™ ready, 2000 series Intel® Core i3, i5 & i7 ready, LGA1155 socket compatible
System Bus: Intel® QuickPath
Memory support: 2 x DDR3-1333 DIMM slots (dual-channel)
Memory capacity: Up to 16GB
Expansion: PCI Express x16, Mini-PCI Express (occupied by WiFi card)
SATA: 2x SATA 6.0 Gb/s, 4x SATA 3.0 Gb/s w/ RAID 0, 1, 0+1 & 5, 1x eSATA 3.0 Gb/s
Display outputs: DisplayPort, HDMI, DVI-I & VGA (with included adapter)
WiFi: 802.11n (300 Mb/s)
Ethernet: 10/100/1000Mbps
USB : 4x USB 3.0 ports (2 on back panel, 2 via pin headers/included bracket), 8x USB 2.0 ports (4 on back panel, 4 via pin headers)
Audio: 8-channel high-definition audio, HDMI audio output (lossless bit stream ready), Digital S/PDIF (optical) output
DirectX® support: DirectX® 10 with Shader Model 4
Other hardware features: OpenGL® 2.1, Intel® InTru™ 3D, Clear Video HD and Quick Sync Video technology ready (Intel® HD Graphics 2000/3000 required)
Windows® 7 capability: Certified for Windows® 7 premium®
-Thomas Jefferson
gwolfman
Re: ZOTAC combines LGA115 processors with mini-ITX form fact
Post by gwolfman »
Sweet, this might be my next HTPC and/or NAS. :supz:
