Memory question
sbohdan
Memory question
Post by sbohdan » Fri Feb 04, 2011 10:41 pm
Just wanted to ask (I found no information on this anywhere), if a 1.65V memory woul be OK for my future sandy bridge platform? The memory in question is optimized for P55 chipset (according to OCZ's website) and I found no info on compatibility for P67, which uses 1.6V memory...
this is the memory: http://www.amazon.com/OCZ-Technology-PC ... 638&sr=8-1
here it is on OCZ website: http://www.ocztechnology.com/ocz-ddr3-p ... annel.html
could anyone enlighten me on this? :prayer:
oh and if it's Ok - do you think it would be good memory for an OC (intel 2500K + Gigabyte GA-P67A-UD4)? This memory is CL10 timings - should I rather get something lower on Mhz but tighter on timings? :ANAL:
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte GA-P67-UD4-B3, [email protected],1.428V, 8GB GSkill Ripjaws 2133Mhz [email protected], MSI GTX 1060 3GT OC, Asus 24" 1ms 144hz, 2xOCZ Vertex4 128GB RAID0, Samsung 2TB; PC P&C 750W, Win7 Ultimate 64
sbohdan
Re: Memory question
Post by sbohdan » Mon Feb 07, 2011 6:50 pm
Anybody? I can't believe nobody knows the answer?! ](*,)
skier
Re: Memory question
Post by skier » Tue Feb 08, 2011 1:01 am
that's very fast memory, and very expensive for the density you are getting, I have no idea about specific compatibilities but i doubt you would have a problem with sandy and RAM voltages, 1.65v is what some 1600MHz kits run at
-Austin
Screamin' BCLK: Image
