Playing with ROMs on my Droid
A place to talk about all things mobile
Illuminati
Post by Illuminati »
So I finally took some time to install a custom ROM on my Droid X last night and ended up installing the Tranquility 3.7 ROM. Its nice, but I'm already interested in trying some other ROMs, so I was wondering if anyone else out there has found a ROM they think is great!
I'm interested in finding a ROM that feels like a new OS... the Tranquility ROM gets rid of the bloat and adds the ability to customize a lot of things and different themes, but it still feels like the same old stock OS to me and I'm looking for a little different.
Here are a couple of screenshots of my Droid using Tranquility 3.7 and the RedX theme that is available in Tranquility Tools.
RedX Desktop
RedX Desktop
Apps Screen
Apps Screen
Justin West
Server Admin & Forum Moderator
Follow me on Twitter | Find us on Facebook
Major_A
Re: Playing with ROMs on my Droid
Post by Major_A »
Can't comment on the ROMs yet. I rooted my EVO 4G but since I deleted/stopped/adjusted the stock apps I'm content. What are you using to find ROMs?
http://www.appbrain.com/app/rom-manager ... rommanager
Illuminati
I did use Rom Manager to install tranquility, but I didn't use it to find it... I've just been manually searching for droid x roms and reading about some of them on various forums.... not very efficient :)
Justin West
Major_A
Post by Major_A »
You have a leg up on me. I have no idea what ROM to try. There are literally hundreds of them over xda's EVO forum.
EDIT
Let me ask you this. When you installed a new ROM is it essentially like formatting your PC and starting over? I would hate to have to reinstall all my apps over and over until I found a ROM I liked. (Note: I do have AppMonster so it wouldn't be that big of a pain, but a pain none the less.)
Illuminati
Yes, you wipe the system when you install a mod... I used Titanium Backup and it backed up all my apps (that I chose for it to backup) and once the rom was installed, I used titanium backup to restore the apps I told it to. Took a bit to install 54 apps, but at least it was an automated way (sort of) to keep all of my apps without having to remember what I need to install.
Justin West
HONkUS
Post by HONkUS »
CyanogenMOD 7 Nightlies have been at a very polished state for a long time now on the OG Droid. You should give it a try! CM 7 has a lot of nice features! You should make sure you have a recovery that support the new Gingerbread ROM's though, Clockwork Recovery 3.X works well.
Illuminati
Yes, CyanogenMod looks to be one of the best out there. Unfortunately, the Droid X is not supported by CyanogenMod because that ROM requires an unlocked bootloader and the Droid X/2 seem to be locked forever.
Justin West
