enter M.I.T. and then the advanced frequency settings:
here leave the CPU clock ratio @ default (33x for 2500K), I did not touch the BCLK and chose profile1 for the memory. Bios set my memory to 1600 by default but it is capable of 2133Mhz, so I just chose the SPD profile of my RAM. In case your memory's SPD isn't read properly, you can adjust it manually in the memory menu.
next, enter the Advanced CPU core features and leave the CPU clock ratio @ default (33x), change the turbo ratio value for each core to 47 and raise the turbo power limit to 200W. leave everything else @ auto.
next, in M.I.T enter the Advanced voltage settings and enable load-line calibration. change the CPU Vcore to 1.425V. I left everything else on auto again.
thats all. The OC is rock solid, you still have all the power saving features on but will have the OC WHEN you need it.
BTW, all this resulted in 4.7Ghz (exactly 4689Mhz). CPU-Z shows 1.404V because of V-drop. I know this isn't top OC, since sandybridge is said to reach 5Ghz but I feel that having air cooling, this is a safe and to me a satisfactory OC, that I can use 24/7.
