i7-2720QM runs hot?
mitrichr
Legit User
Legit User
i7-2720QM runs hot?
Post by mitrichr » Sun May 22, 2011 12:55 pm
On my i7-2720QM, I am seeing temps for the four at around 78-80C.
I have two other i7's and an i5, I do not see temps this high.
This is not a gaming machine. It is used for normal work and home applications plus "crunching" data for projects running on BOINC software.
Major_A
Re: i7-2720QM runs hot?
Post by Major_A » Sun May 22, 2011 3:17 pm
Is the processor throttling or causing apps to crash? If not then it's not that big of a deal. We have been engrained into thinking that anything over 60 degrees is BAD. But if the computer is still stable, who cares.
mitrichr
Legit User
Legit User
Post by mitrichr » Sun May 22, 2011 3:23 pm
Thanks, no everything is running fine. The computer is new, this is something I always check. My laptops run 24/7 on BOINC projects, so, you know, heat is a dirty word.
I appreciate your comments.
DragonFury
Post by DragonFury » Mon May 23, 2011 10:24 am
is it during idle or during loads? full load with temps like that on a laptop then I say it is normal. if its low usage or idle temps then you have a serious issue.
Mini ME
Is in a state of flux....
mitrichr
Legit User
Legit User
Post by mitrichr » Mon May 23, 2011 10:52 am
Hi-
The load does not matter. The machine was just "crunching' most of the week-end, temps maybe 65-85C. Now, at work, doing real work and crunching, the temps are the same, maybe 66-85C.
mitrichr
Legit User
Legit User
Post by mitrichr » Mon May 23, 2011 6:52 pm
I think I pretty much found the culprit. Some of the projects running on BOINC software on my computers will use the graphics processing. They are demanding in what they will use, and up until now, I did not in any of my other machines have suitable graphics processing. So, one project jumped on the GPU in the new system. I have stopped that and now my temp readings on the CPU are in the 60-70C range.
I know that graphics and the CPU are separate; but I also know that there is something about graphics processing involved with Sandybridge.
You can correct any misstatements I am making, and I will appreciate it.
The main point is, I stopped the GPU processing and the temps went down to what I would expect.
Major_A
Post by Major_A » Mon May 23, 2011 9:49 pm
I don't know what core your CPU is running but the newer i series have the GPU built-in to the CPU.
mitrichr
Legit User
Legit User
Post by mitrichr » Tue May 24, 2011 4:57 am
Yes, that's Sandybridge. But, the computer has nVidia GeForce GT555M. That shows up separately in Device Manager|Display adapters, and that is what the BOINC project was using.
DragonFury
Post by DragonFury » Tue May 24, 2011 10:18 am
it could share the same heatsink so when you work one part the other heats up a bit too. common on laptops because of lack of room.
Mini ME
mitrichr
Legit User
Legit User
Post by mitrichr » Tue May 24, 2011 11:21 am
Yup. Well, all's well that ends well.
I really would like to be able to crunch with GPU, the run up of credits is unbelievable. So, maybe on my next desktop I will buy with parts in mind to allow it.
But, hey, I am in the 99th percentile of all BOINC crunchers in the history of BOINC, and that was my goal. I am not really a credit hound, rather, I love contributing to the scientific research in whatever little way we do, and I can afford to have six pretty new PC's., so what with hyper threading, I am processing 32 work units at one time 24/7.
sbohdan
Post by sbohdan » Tue May 24, 2011 11:51 am
In laptops the CPU and the GPU cooling is done by the same cooler (connected by heatpipes), so yes, when the GPU is under load it raises the heat load of the same cooler, so the extra heat is understandable. On the other hand I would feel very uncomfortable if my laptop's CPU would heat up to 85C for two reasons: the CPU's silicone layer doesn't like long time high temperatures like that and the overall lifespan might be significantly shortened and the other that other chips and parts might be also negatively affected on the motherboard (heat is #1 enemy of computer parts). If I was you I wouldn't use a laptop for this kind of work load (I assume you are using your lap 24/7). I would also change the thermal paste on the CPU and GPU to something of a high quality (ex. tuniq TX-2, 3 or 4). My laptops temps went down almost 10C just because of the TIM change :roll:
Main rig: NZXT Phantom modded case with Danger Den WC, MSI Tomahawk B350, Ryzen 1700X @ stock, 16GB Patriot Viper DDR4 3200Mhz 16-18-18-36, AMD RX 5700XT + AlphaCool WC, ACER Nitro XV2 27", Intel P7600 256Gb nvme PCiE, Samsung 2TB; Cooler Master MW Gold 650W, Win10 Pro 64
Laptop: Dell XPS 1530 (T9500; 4GB 800 RAM; 120GB Crucial SSD; 8600GT; WIN10 pro 64bit)
mitrichr
Legit User
Legit User
Post by mitrichr » Tue May 24, 2011 12:34 pm
I think that things are now fine, temps in the 60'sC. That is in line with all of my other machines. I just had to get rid of the GPU crunching.
danman132x
Legit Little One
Legit Little One
Post by danman132x » Wed May 25, 2011 4:56 pm
Sounds normal to me. I had the 2720QM since launch back in January and was always worried it was running too hot. Now that it's been out a while, it seems to be normal in laptops to run like that from various sites I have been searching. I made a lil stress test video for youtube showing the temps and cpu speed.
http://www.youtube.com/watch?v=snJChhU2TGo
mitrichr
Legit User
Legit User
Post by mitrichr » Wed May 25, 2011 8:39 pm
danman-
Thanks so much for the demonstration. I really appreciate your work.
danman132x
Legit Little One
Legit Little One
Post by danman132x » Thu May 26, 2011 12:07 am
I would love to open my laptop up and apply some better thermal paste like Artic Silver, but I don't want to void the warranty on it. I have it until next January, and they also just swapped out my motherboard due to the chipset issue. I am very comfortable taking my laptop apart, but then the warranty issue arises. I will definitely do it once it expires. And as stated above, the CPU and graphics processor use the same heatsink. It's time they design some better heatsinks for laptops or add two fans if necessary to keep the air flowing.
duyancomputer
Legit Little One
Legit Little One
Post by duyancomputer » Mon Jun 05, 2017 10:32 am
Somehow my i7 2720qm, the average temperature 66-70oC, do not know so okay
https://thumuamaytinhcupc.wordpress.com thu mua may tinh cu - 0938.526.806 an
https://duyancomputer.com thu mua laptop cu gia cao
