Pioneer DJ is offering a free firmware update for its DJM-T1 2-Channel TRAKTOR Mixer that adds multiple features and improved control functions for use with TRAKTOR™ SCRATCH 2 DJ software including an Advanced Shift Mode consisting of six additional effects options, extra Hot Cues, and more. The free firmware version 2.00 update is available for download at http://www.prodjnet.com/support/download.php.
A video demonstration using the updated firmware on DJM-T1 with TRAKTOR SCRATCH 2 software can also be viewed here.
The DJM-T1 “Advanced Shift Mode” firmware update for use with TRAKTOR SCRATCH 2 includes:
Increased Function Control with Advanced Shift Mode – The new feature offers DJs control over more software functions including the ability to assign up to three different function operations for each button and knob on the mixer.
Added Effects Options and Controls – In addition to the existing TRAKTOR SCRATCH 2 effects assigned to FX1 and FX2, the new firmware allows the control of six more effects assigned to FX3 and FX4 for a maximum of 12 effects to be controlled using the DJM-T1’s buttons and knobs.
More Hot Cue Points – The update increases the ability to add and play four additional Hot Cue points for both Deck A and Deck B for a total of eight possible Hot Cue points.
Ability to Input Grid Information & Adjust Grid Location – By using Advanced Shift Mode, DJs can input their own grid information and adjust grid location to perform the software functions of Sync, Quantize and Snap with more accuracy.
More functions with Sampler slots – Enables users to adjust volume and switch between One Shot and Loop modes for each sampler slot.
Additional functions include:
Tempo Reset ON/OFF control
Master Tempo ON/OFF control
Select from playlists registered in user’s Favorites
Start/Stop recording
Return to the start of the track playback
Waveform display size adjustments
Page through user’s track list
Ability to switch display of the Advanced Panel
Load Cue settings
Track Fast-forward and rewind
The DJM-T1 with TRAKTOR SCRATCH DUO 2 DJ software is available at Pioneer DJ retailers for a suggested retail price of $1,899.
For more information about the DJM-T1, visit: http://www.pioneerdjusa.com/gear.aspx?p ... JM-T1&cp=3
Pioneer DJM-T1 TRAKTOR Firmware Update
- Apoptosis
- Site Admin
