forgotten Win XP password
Operating Systems
If its an OS, its here.
camaroguy1998
Post by camaroguy1998 » Fri Apr 20, 2012 7:17 pm
Is there a way to retrieve or change the windows log on password?
A friend has forgotten his password. I dont want to reload Windows if I dont have to!
There is data he would like to keep.
Last edited by camaroguy1998 on Sat Apr 21, 2012 10:47 pm, edited 1 time in total.
ASUS BW-12B1ST BD Burners(X2)
EVGA 560ti SC
ASUS 27" LED LCD monitor
Corsair 600T case
kenc51
Re: forgotten Win XP password
Post by kenc51 » Sat Apr 21, 2012 5:14 am
camaroguy1998
Post by camaroguy1998 » Sat Apr 21, 2012 11:57 pm
kenc51 wrote:Linux System Rescue CD
http://www.howtogeek.com/howto/windows- ... rescue-cd/
Thank You Kenc51!
Unfortunately it did not work.
After it failed I talked to the owner again and got a little different story.....
Apparently he forced a shut down while windows was running updates,
Even though it told him not to turn it off or cut power.
I tried to do a windows repair but its asking for a password, which it does not accept.
Anyone have any ideas?
EVGA 560ti SC
Corsair 600T case
kenc51
Post by kenc51 » Sun Apr 22, 2012 6:47 am
Will it boot at all?
If it does, try booting into SAFE mode. You might be lucky and he left the default "Administrator" account alone and you might be able to login with user: Administrator and no password.
In fact, try the repair again and use "Administrator" and no password.
You could also try "Last Known Good Configuration" from the boot menu (press F8 at boot)
The next option is to "hack in"
You can use Linux (again) and use "0phcrack" to get the password using rainbow tables.
It can get the Windows password in a couple of minutes, as long as it's 14 charachters or less.
Anything longer might be a problem and could take a while, but still can be done.
http://ophcrack.sourceforge.net/ --> use the live CD.
There's also a Windows .exe, but you'll need to move his hdd to another bootable PC to use this.
I haven't used it, but the FAQ and instructions are below
http://sourceforge.net/apps/mediawiki/o ... ck_Support
Ken
Major_A
Post by Major_A » Sun Apr 22, 2012 11:57 am
kenc51 wrote:http://ophcrack.sourceforge.net/ --> use the live CD.
I've used this in the past with varying results. One computer I had to use it on gave me the password to the non administrative account. That did me virtually no good.
camaroguy1998
Post by camaroguy1998 » Sun Apr 22, 2012 6:09 pm
Here's a little more info....
It will boot to the windows login screen. It has his name when you click on it, it asks for the password. Which is rejected.
I used the Linux/RescueCD and changed the password(or at least went through the process) When trying to login it still rejects any password, old or new. I am able to boot into the BIOS and when I check the settings under the security tab it says both the Administrator and System passwords are NOT SET! That I find strange.
I'm going to try the safe mode boot and see what happens!
Thanx for all the ideas!
EVGA 560ti SC
Corsair 600T case
camaroguy1998
Post by camaroguy1998 » Sun Apr 22, 2012 7:31 pm
I was able to boot into the SAFE mode and access the UAC and remove all passwords.
It now boots up without issue!
Thank You! :prayer:
Made my friend extremely happy!
:supz:
EVGA 560ti SC
Corsair 600T case
Major_A
Post by Major_A » Sun Apr 22, 2012 10:05 pm
Jeez, didn't know it was that easy to remove passwords. If that's true in all Windows installs then it kind of defeats the purpose of the password. Thanks for sharing and glad you got it working.
camaroguy1998
Post by camaroguy1998 » Sun Apr 22, 2012 11:36 pm
Major_A wrote:Jeez, didn't know it was that easy to remove passwords. If that's true in all Windows installs then it kind of defeats the purpose of the password. Thanks for sharing and glad you got it working.
I hear you...I was amazed!
I worked on this thing for 5-6 hrs.
and when I tried the Safe mode boot, had it fixed in less than 10 mins. :shock:
Thanx for your ideas!
Thanx Kenc51!
Your help is greatly appreciated! =D>
EVGA 560ti SC
Corsair 600T case
kenc51
Post by kenc51 » Mon Apr 23, 2012 3:03 am
It should never be difficult to get into systems when you have physical access to the box. Sure, you can further lock it down; but what's the point.
When you boot in to Safe Mode (or run single user mode) there's no network connection, so this can't be done remotelty.
This is true for both Windows and Linux/Unix.
Thanx Kenc51!
Anytime
alina350
Legit Little One
Legit Little One
Post by alina350 » Tue Jun 11, 2019 3:53 am
Major wrote:https://www.winpwd.com --> use the live CD.
WinPWD is still capable of recovering password from old Windows versions like XP to latest Windows 10. Just tested it 3 devices without any problem.
