Question
sbohdan
Question
Post by sbohdan » Sun May 05, 2013 2:20 am
Can anyone explain in plain words what does Intel® Virtualization Technology means and what are it's benefits in real world applications if any? I have reaad the wikipedia article but I can't understand - too technical for me. Should I enable it in BIOS of my laptop (the T9500 is capable of it) or not?
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte GA-P67-UD4-B3, [email protected],1.428V, 8GB GSkill Ripjaws 2133Mhz [email protected], MSI GTX 1060 3GT OC, Asus 24" 1ms 144hz, 2xOCZ Vertex4 128GB RAID0, Samsung 2TB; PC P&C 750W, Win7 Ultimate 64
KnightRid
Re: Question
Post by KnightRid » Sun May 05, 2013 5:03 am
As simple as I can get it - new instructions for virtual computing using programs like vmware, virtual pc, etc. It will hurt nothing to leave it on as it does not effect performance from what I have seen.
Basically, if it was on, let it on. If it was off and you wont run virtualization programs, let it off.
My opinion, hopefully someone else will chime in to make sure as I do not use vmware much at all.
skier
Re: Question
Post by skier » Sun May 05, 2013 6:28 am
Knight is correct, it is pretty much only for if you are running a virtual machine (virtual box, vmware etc.) if you don't plan to have a VM I would just leave it off (Myself I have 4 different virtual OS's on my work laptop to stay familiar with them; at Help Desk)
-Austin
Screamin' BCLK: Image
sbohdan
Re: Question
Post by sbohdan » Sun May 05, 2013 12:00 pm
Thanks guys. I'm not using vmware, so I guess I don't need it. Thanks for clarifying :prayer:
