Zotac GTX 570 thermal pads!
DJ Tucker
Post by DJ Tucker » Mon Jul 08, 2013 5:09 pm
I took my 570 apart and i noticed that 2 of the ram chips do not have thermal pads on neither do any of the power phases. I also noticed that the pcb right where the power phases and vrms are gets to 65c at full load the core gets to 68c with room temps at 24c. God knows what the temps are of the power phases and vrms. So i just ordered some Phobya Thermal Pad Ultra 5W/mk. i will replace all the pads. However, i can't put pads on the power phases due to there being no room. What can i do and is it the power phases that heat up or the vrms?
This is my GPU http://www.zotacusa.com/geforce-gtx-570 ... 3-10m.html
Unable to find the a pic with the heatsink off so you can see the design underneath.
Armageddon V1.0
Processor: Core i7 9700k 4.6Ghz @ 1.15v Barrow 360 Loop
Memory: 16Gb Corsair Vengeance LED 2700Mhz CL15
Hard Drive: Silicon Power P32A80 128Gb & Intel 660p 2Tb
Video Card: Gigabyte RTX 2070 Heatkiller IV Block 1995Mhz @ 0.950v
Power Supply: Corsair HX1000i
Monitor: Samsung 1080p C27F396
Mobo: ASRock Z390 Phantom Gaming 6
Case: Vector VDM01
Peripherals: Corsair K70 Lux, M65 Pro, MSI GC30 and Void Pro Wireless
skier
Re: Zotac GTX 570 thermal pads!
Post by skier » Mon Jul 08, 2013 9:40 pm
Generally if it doesnt come with them it doesnt need them (65c is warm but they are designed for much hotter) keep in mind they are designed to run without overheating at load in ultra stuffy or dusty smoker's cases without touching the thermal compound, I've never worried about them on any card i've had at least
Cant really say much as far as what component is what without seeing the PCB
-Austin
Screamin' BCLK: Image
DJ Tucker
Post by DJ Tucker » Tue Jul 09, 2013 5:02 pm
65c is the pcb temp reading using an adhesive temp sensors from the aerocool touch 1000. anyway here is a pic of the zotac gtx 560 ti 448 edition which is the exact same pcb layout at my zotac 570. in fact the 560 ti 448 is a 570 with few less SPU's http://www.overclock.net/t/1326175/sli-gtx-560-ti-448
Armageddon V1.0
Case: Vector VDM01
