Supercooled Rig!
DJ Tucker
Supercooled Rig!
Post by DJ Tucker » Sat Oct 05, 2013 8:23 pm
One of my gaming buddies has a supercooled rig that he put together himself 6 months ago.
His Rig =P~
i7 4930k @ 4.0ghz
2 gtx 780 @ stock
3x 2tb hard drives
64gb of curcial ddr3 @ 1066
Alienware Aurora R3 motherboard
After he told me his temps i was amazed.
CPU: Idle @ 18c Load @ 28c
GPU: Idle @ 12c Load @ 38c
I found out that his cooling system has a special gel that you put in freezer overnight then put into the cooling system the next day. you have to fill the reservoir and allow the pump to push all the gel around the system then fill the remaining space in the reservoir and repeat until the cooling system is free of air. once you have done this then the gel remains at 2c and doesn't need replacing for 8-10 years =D> not only is he rig a beast but those temps are unbelievable until he showed me a pic. Pictures of the Rig and Temps will be uploaded as soon as he sends me them :)
Armageddon V1.0
Processor: Core i7 9700k 4.9Ghz (AVX 4.9Ghz) @ 1.264v Barrow 240mm+360mm
Memory: 16Gb Corsair Vengeance LED 2700Mhz 16-16-16-32-1T
Hard Drive: Silicon Power P32A80 128Gb & Intel 660p 2Tb
Video Card: RTX 2070 Heatkiller IV 2010Mhz @ 0.975v
Power Supply: Corsair HX1000i
Monitor: Lenovo L24Q-10 1440P
OS: Windows 10 64 bit Pro
Mobo: ASRock Z390 Phantom Gaming 6
Case: Vector VDM01
Peripherals: K70 Lux, M65 Pro, and Void Pro Wireless
Major_A
Re: Supercooled Rig!
Post by Major_A » Sun Oct 06, 2013 10:54 pm
Uh, what? Ask him for links to the stuff and post it here if you don't mind.
DJ Tucker
Post by DJ Tucker » Mon Oct 07, 2013 5:05 am
he can't find the website for this stuff. he's gets his stuff dirt cheap but we are having a look about on the web.
just changed is system specs now that he got a program i gave him working :lol: just waiting on the pictures then will be testing the rig to the max for true temps :)
Armageddon V1.0
Case: Vector VDM01
DMB2000uk
Post by DMB2000uk » Tue Oct 08, 2013 8:22 am
If you need to freeze the gel to get its temperature down to 2ºC, then it's not going to stay at (or return to) 2ºC when you add the heat from the PC. Especially if you're then only cooling it again with ambient air.
If the gel is chilled when put into the cooling loop, those temperatures are possible, but they're going to get steadily worse the longer the gel has been out of the freezer until they're no better than other normal watercooling setups (and potentially worse depending on the specific heat capacity of the gel compared to normal water).
Image (<- Clickable)
skier
Post by skier » Wed Oct 09, 2013 11:32 am
DMB2000uk wrote:If you need to freeze the gel to get its temperature down to 2ºC, then it's not going to stay at (or return to) 2ºC when you add the heat from the PC. Especially if you're then only cooling it again with ambient air.
Unless it is like a phase setup or the 'gel' is really a type of A/C coolant
But its doesn't sound like either of those things
Moral of the story: Pics or it didn't happen :lol:
-Austin
Screamin' BCLK: Image
