Question regarding saving program files
Keith
Legit User
Legit User
Post by Keith » Sat Mar 22, 2014 7:04 am
I'm not sure if this is the right place to ask this question, but here goes:
I have been downloading photoshop and Lightroom software from adobe. It is literally taking days to complete. Is there any way that I can save these files to an external hard drive so that I won't have to go thru this again if my laptop fails? IF so, how would I go about it?
I'm running windows 8.
Thanks
Major_A
Re: Question regarding saving program files
Post by Major_A » Sat Mar 22, 2014 10:22 am
Just save the installer package.
KnightRid
Post by KnightRid » Sun Mar 23, 2014 4:42 am
If it is an automated installer that you download a smaller file and then it download the big file, it would be a bit difficult to save the big file. If you download the huge file directly then you can do just like the Major said, save to an external drive or you can burn to a dvd/bluray for storage too.
viv_smith
Legit User
Legit User
Post by viv_smith » Fri Sep 12, 2014 12:33 am
it was possible to keep both installation packages a couple of years ago... unfortunately, since adobe released adobe creative cloud, now there is a single installer, which gives you access to all adobe programs...
Computers follow your orders, not your intentions.
Upcoming iOS/Android games for 2015.
