Dynamic disk offline error
DJ Tucker
Post by DJ Tucker » Fri May 30, 2014 9:04 am
I have a western digital green 1tb that I got from a friend. he told me he wanted and bigger hdd so I got this one. however, when connecting it to my pc I realised it was set as a dynamic disk and gpt. it is online but I can't do anything with it as it is saying the volume is offline when it's not. anything I can do here? :)
Armageddon V1.0
Processor: Core i7 9700k 4.8Ghz (AVX 4.8Ghz) @ 1.248v Barrow 240mm+360mm
Memory: 16Gb Corsair Vengeance LED 2666Mhz 14-16-16-32-1T
Hard Drive: Silicon Power P32A80 128Gb & WD Blue M.2 Ssd 2Tb
Video Card: RTX 2070 Heatkiller IV 1995Mhz @ 0.987v
Power Supply: Corsair HX1000i
Monitor: Lenovo l24q-10 1440p
OS: Windows 10 64 bit Pro
Mobo: ASRock Z390 Phantom Gaming 6
Case: Vector VDM01
Peripherals: K70 Lux, M65 Pro, and Void Pro Wireless
InspectahACE
Re: Dynamic disk offline error
Post by InspectahACE » Sat May 31, 2014 11:27 am
I'm not entirely sure but I found a link that might help. It's possible you may already have tried too.
http://technet.microsoft.com/en-us/libr ... 32026.aspx
i7 6700k | ASUS H170M-PLUS | EVGA GTX 980 Ti | 16GB G.Skill Ripjaws V DDR4-2400 | Cooler Master Hyper 212 Evo | WD Black NVME 500GB SSD | Corsair Force GT 240 GB SSD | Sound Blaster Z | Corsair CX750M 750w PSU | Logitech G502 | Logitech G810| BenQ Zowie XL2730 27" monitor | Windows 10 Home 64-bit
DJ Tucker
Post by DJ Tucker » Sat May 31, 2014 5:51 pm
yes already done this but I found a way to get it to work. however, it's seems that the file type is RAW not NTFS and cannot be converted. what can I do here? :(
Armageddon V1.0
Case: Vector VDM01
InspectahACE
Post by InspectahACE » Sat May 31, 2014 7:10 pm
as long as the data is not important, you should be able to just reformat it.
KnightRid
Post by KnightRid » Sun Jun 01, 2014 2:40 am
InspectahACE wrote:as long as the data is not important, you should be able to just reformat it.
That
Also, if there is data you want to get back just run a recovery program on it. Could take quite a while but if the data is important that is the only thing you can do.
I would also test that drive thoroughly before putting anything I do not want to lose on it.
DJ Tucker
Post by DJ Tucker » Sun Jun 01, 2014 4:31 am
there is no data on there, I did last night do a full format but it failed for some reason. the is detected and windows starts fine but a can't format it. is it possible to have bad sectors that can't be repaired?
Armageddon V1.0
Case: Vector VDM01
kenc51
Post by kenc51 » Sun Jun 01, 2014 10:19 am
Have you scanned the drive for bad sectors? I'd try that first & choose the option to repair.
If you've done this already, try reformat via a bootable linux distro like gparted or even Ubuntu. Make sure to delete the partition(s) before formatting as otherwise they might still be picked up as dynamic disks again.
DJ Tucker
Post by DJ Tucker » Sun Jun 01, 2014 5:25 pm
ok so I did a check disk and it now correcting errors in the volume bitmap and has been doing so for the last 6 hours with over 40 lines saying the same thing?
Armageddon V1.0
Case: Vector VDM01
kenc51
Post by kenc51 » Wed Jun 04, 2014 1:29 pm
How's it going? Did the repair work?
Sent from my Nexus 7 using Tapatalk
DJ Tucker
Post by DJ Tucker » Wed Jun 04, 2014 5:16 pm
it was just saying correcting errors in the volume bitmap. never went any further. I gave up after 10 hours as I came home from work and it still wasn't done :cry:
Armageddon V1.0
Case: Vector VDM01
kenc51
Post by kenc51 » Wed Jun 04, 2014 5:46 pm
Try the bootable linux option - failing that you can use "MHDD"
http://hddguru.com/software/2005.10.02-MHDD/
Use Unetbootin to copy to a usb key
It will scan and try fix any bad sectors, but also correctly mark the bad ones as dead and this way you can usually recover data.
You can also try a low level format using this (write zeros to all sectors)
You also might get a smaller drive (depending on how many bad sectors are marked as bad (this is adjustable btw so you can make a <1TB drive 1GB and that 1GB be the outside of the platter - so super quick; only problem is that it's irreversible))
Basically, if there is no (bad) mechanical noise you can probably save it.
DJ Tucker
Post by DJ Tucker » Thu Jun 05, 2014 7:52 am
writing zeros to the drive now but it's going to take 2700 hours, about 110 days??? it's going really really slow. any reason as to why?
Armageddon V1.0
Case: Vector VDM01
kenc51
Post by kenc51 » Thu Jun 05, 2014 2:09 pm
It should take a few hours, sounds like a faulty sata cable or port
DJ Tucker
Post by DJ Tucker » Thu Jun 05, 2014 3:00 pm
ok so I tried it in all my available ports and same thing over and over. I even used Easeus Partition Manager and still nothing worked. I have no idea what to do. windows recognises the drive but fails to format and check disk repeats correcting errors in the volume bitmap. seems it's stuck in RAW format and that's as far as I can go :(
Armageddon V1.0
Case: Vector VDM01
kenc51
Post by kenc51 » Thu Jun 05, 2014 3:55 pm
That sucks... The only thing I can think of is to use a linux live cd & format using that
