Solid-State Drive Catches on Fire and Dies Dramatic Death
Post by Apoptosis » Thu Jun 19, 2014 4:59 pm
Plugged in a Corsair P256 SSD off the shelf to move some files around in the test lab and when the system fired up I noticed smoke and the SSD cable was glowing red with a bit of a flame. I kicked the power off and the drive is toast, but the other SSD that was plugged into the same power cable is just fine. Never had an SSD catch on fire and burn up like that.
Here are a couple pictures. The plastic was still soft when I pulled the power cable off the drive. The plastic hardened on the SATA power connector and I used a screw driver to get it off and that is why the pins there are jacked up. The copper wire pins in the PSU modular cable are melted away and gone. Not sure what happened, but just wanted to share.
InspectahACE
Re: Solid-State Drive Catches on Fire and Dies Dramatic Deat
Post by InspectahACE » Thu Jun 19, 2014 5:54 pm
:shock: :shock: :shock:
i7 3930K @ 3.8 Ghz | Asus Rampage IV Extreme | Asus GTX TITAN SLI | 16GB G.Skill Ripjaws Z DDR3-1866 | Corsair H100i | Corsair Force GT 90 GB SSD | 2x Corsair Force GT 240 GB SSD | 450GB VelociRaptor | Sound Blaster Z | Corsair AX1200i PSU | Logitech G502 | Logitech G810| CM HAF-932 Black Edition | BenQ Zowie XL2730 27" monitor | Windows 10 Pro 64-bit
kenc51
Post by kenc51 » Fri Jun 20, 2014 10:31 am
Sounds like the ground wire somehow crossed the live - I killed a psu by rewiring a molex connector backwards
Post by Apoptosis » Fri Jun 20, 2014 2:31 pm
kenc51 wrote:Sounds like the ground wire somehow crossed the live - I killed a psu by rewiring a molex connector backwards
yeah, but I pulled it off the optical drive and plugged it into the SSD.... No wire switching ever and the drive that was further down the power cable was fine.
sbohdan
Post by sbohdan » Sat Jun 21, 2014 11:48 pm
Sounds like the short was inside the SSD.
Main rig: NZXT Phantom modded case with Danger Den WC, MSI Tomahawk B350, Ryzen 1700X @ 3.4Ghz, 16GB Patriot Viper DDR4 3200Mhz 16-18-18-36, MSI GTX 1060 3GT OC, Asus 24" 1ms 144hz, Intel P7600 256Gb nvme PCiE, Samsung 2TB; PC P&C 750W, Win10 Pro 64
