New SSD causes cpu overclock to be unstable?
- DJ Tucker
as the title says got an issue with my cpu overclock. I had 4.4ghz stable @ 1.22v but that same overclock using occt linpack is unstable and crashes between 8mins 30secs and 8mins 40secs. this happens just as cpu drops to 25% and jumps to 100%. the instant it does that error detected and I can't figure out why. upped voltage up to 1.3v and same issue at the same time?
MSI Z590 Gaming Edge Wifi
Corsair XR5 240mm x2 & 360mm
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
- Apoptosis
- Site Admin
Re: New SSD causes cpu overclock to be unstable?
I'm not a huge fan of OCCT as it puts more load on the system that you'd ever encounter in normal daily use as a consumer.
could be due to a 5V fluctuation in your PSU. SSD's usually can't handle much of a voltage drop and cause system issues. If you SSD is having issues that will cause Windows to freeze up obviously.
- DJ Tucker
ok so I have it stable at 4.4ghz @ 1.22v again. it turns out a game I was running the night before that crashed my system was the culprit. I uninstalled the game and my overclock became stable again. installed the game and unstable overclock. shame as I liked that game. even installing this game on my secondary HDD gave the same issues
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
That's wierd. What game?
-Thomas Jefferson
-Thomas Jefferson
- DJ Tucker
world of tanks. turns out it installed into program files and should have installed into program files x86 which it has now and is working fine. very strange.
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
