Minimalist 4K
Velo:Sity
Minimalist 4K
Post by Velo:Sity » Mon Apr 18, 2016 11:07 am
I'm going to upgrade a fairly old machine (Athlon II X4, GeForce GTX460) with main requirement being ability to connect a 4K screen to it and watch 4K videos without lag. I don't want to overpay for extra power I won't use, so the question is what is the most efficient route to achieve this...
KnightRid
Re: Minimalist 4K
Post by KnightRid » Tue Apr 19, 2016 4:26 am
https://linustechtips.com/main/topic/24 ... ii-x4-640/ - doesn't look good
I have not looked to see if there are any players that will use GPU but if they do, you would probably need a pretty high end card to do it smoothly.
I also read the GTX460 does not do resolutions above 1600p.
I hate giving good people bad news but here, have a cookie and you will feel right as rain. O:)
Of course someone else may know how to do it but just from a quick search and my gut feelings, it takes a lot to push 4k. I have not even bothered looking into 4k for myself yet.
Oh i forgot, the new Intel chips do have support for 4K built in so you could swap the cpu/mb and probably be golden. I know, not the same as using what you already have.
sbohdan
Re: Minimalist 4K
Post by sbohdan » Tue Apr 19, 2016 7:03 am
I think you are being overly optimistic thinking you can push 4K with old technology like this :)
Main rig: NZXT Phantom modded case with Danger Den WC, MSI Tomahawk B350, Ryzen 1700X @ 3.4Ghz, 16GB Patriot Viper DDR4 3200Mhz 16-18-18-36, MSI GTX 1060 3GT OC, Asus 24" 1ms 144hz, Intel P7600 256Gb nvme PCiE, Samsung 2TB; PC P&C 750W, Win10 Pro 64
bubba
Staff Writer
Staff Writer
Re: Minimalist 4K
Post by bubba » Tue Apr 19, 2016 10:15 am
ehh.. haswell CPUs can play 4K video with the integrated graphics.
Cram as much RAM into that system you can, and slap a GTX7xx series card in there should be fine.
Gamming at 4K, thats a WHOLE other issue.
-Thomas Jefferson
Velo:Sity
Re: Minimalist 4K
Post by Velo:Sity » Thu Apr 21, 2016 4:36 am
Yeah, I know two ways I can go is putting a better GPU that actually supports the resolution (you are right that 460 doesn't) or new-gen motherboard/CPU combo are the ways to go. Wanted to know if anyone has good experience with 4K on lower-end components, like, for example, if passive-cooled GPUs can still play a 60fps 4K video...
KnightRid
Re: Minimalist 4K
Post by KnightRid » Fri Apr 22, 2016 4:33 am
Velo:Sity wrote:Yeah, I know two ways I can go is putting a better GPU that actually supports the resolution (you are right that 460 doesn't) or new-gen motherboard/CPU combo are the ways to go. Wanted to know if anyone has good experience with 4K on lower-end components, like, for example, if passive-cooled GPUs can still play a 60fps 4K video...
you could be the guinea pig :) I do not have a 4K monitor or tv (I still have my 50" 720p plasma which is awesome) so I can not try to test. True 4K content is HUGE also so I could never download a test clip on my computer either since our internet is ungodly slow (said over 14 hours to get a map update for my Garmin....sigh)
bubba
Staff Writer
Staff Writer
Re: Minimalist 4K
Post by bubba » Mon Apr 25, 2016 7:40 am
Dunno.
I have no use for 4K video currently.. nothing I own currently will record it and I'm ok with 720 and 1080 video guess I'm not that picky LOL.
-Thomas Jefferson
Re: Minimalist 4K
Post by Apoptosis » Sat Apr 30, 2016 3:03 pm
Most anything current can stream 4K just fine. I have an office PC with a Broadwell processor (Core i7-5775C) and it plays 4K content just great. Can't game at 4K, but 4K UHD content is fine. A low-end passively cooled Maxwell GPU should be just fine. Not sure if you need to cram that much memory in a system. My Dell XPS 13 Core i7 Skylake laptop has just 8GB of RAM, but it plays 4K content just fine.
Velo:Sity
Re: Minimalist 4K
Post by Velo:Sity » Tue May 03, 2016 8:05 am
Actually even this setup plays 4K 25fps video stretched over a few screens just fine. It's 60fps where the problems begin.
KnightRid
Re: Minimalist 4K
Post by KnightRid » Wed May 04, 2016 5:18 am
Velo:Sity wrote:Actually even this setup plays 4K 25fps video stretched over a few screens just fine. It's 60fps where the problems begin.
Wow, now that is something I would have never guessed it would be able to do! That is awesome for you man!!
i will have to change my thinking on how much power 4K really needs as I have just gone by what I have been reading and ti seems they are all full of it or else getting paid to tell people to buy new hardware :-k
