Windows 10 Boot Issue
DJ Tucker
Post by DJ Tucker » Mon Jul 11, 2016 9:57 pm
So i have an odd issue with windows 10. I was stuck in an auto repair boot loop so i did a startup repair which said it repaired the issue. Before, my system would post, get to blue windows logo with 6 whites dots circling for 5 seconds and black screen for 2 seconds and login screen would show and i'm in.
However, i now get to the blue windows logo and 6 white dots appear to circle before i get a black screen.Then the blue windows logo appears again (instead on login) only the 6 white dots are lagging like a bad game and i'm stuck there indefinitely. To test i left my pc on for 3 hours then cmos button and it just wouldn't move past that screen. i cant do anything other than get into the bios.
Anyone have any idea what is at play here?
Armageddon V1.0
Processor: Intel Core i7 9700k 4.8Ghz @1.25v Barrow 360 Custom Loop
Memory: 16Gb Corsair Vengeance LED 2666Mhz 16-16-16-32-1T
Hard Drive: SanDisk X110 128Gb Sandisk X210 1Tb
Video Card: Gigabyte RTX 2070 Heatkiller IV Block 2010Mhz @ 0.950v
Monitor: Samsung 1080p C27F396FHU
Mobo: Asrock Z390 Phantom Gaming 6
Case: Vector Custom VDM01 with Corsair HX1000i
Peripherals: Corsair K70 Lux, M65 Pro and Void Pro Wireless
KnightRid
Re: Windows 10 Boot Issue
Post by KnightRid » Tue Jul 12, 2016 4:27 am
Do you have a boot cd or usb of Windows 10 (this is the only way I believe to get to repair options and restore options). Boot it and try to repair that way or else restore to a previous time it worked. You can download the iso for free or the media creation tool - https://www.microsoft.com/en-us/softwar ... windows10/
Other thing i saw online was to power down the system when it is at that point then reboot. Do this around 3 times and it starts some sort of auto repair thing...
DJ Tucker
Post by DJ Tucker » Tue Jul 12, 2016 6:09 am
i have just ordered a windows 10 repair disc. unfortunately i cant even get the auto repair to start again by pressing power button 3 times. just get stuck at the logo again. cant use the iso myself as only have 1 windows 10 system the other is windows vista lol.
Armageddon V1.0
KnightRid
Post by KnightRid » Wed Jul 13, 2016 5:49 am
You just need to download and burn it which you could do in vista, 8, 8.1, xp, Millenium, 2000, 3.1, 3.0, 1.0 (ok maybe not 1.0). You just need to boot from it on the windows 10 machine.
DJ Tucker
Post by DJ Tucker » Fri Jul 15, 2016 1:08 pm
unfortunately I couldn't burn the disc as it failed so I went ahead and ordered one and the startup repair failed. had to do a complete reinstall but some how it saved all my documents and games. All that was in my windows.old folder was windows and that was it :)
Armageddon V1.0
