HDMI to IPTV - Asus Router issue
A place to talk about A/V receivers, Blu-Ray players, LCD or Plasma TV mounting, audio tips or anything else that you think fits.
thickglass
Legit Little One
Legit Little One
Post by thickglass » Mon Oct 03, 2016 2:56 pm
Hi guys, I decided to deploy my home theater feed to PC, so I use HDMI QAM modulator, it outputs DVB-C and IPTV as well, now I have MPTS RTP stream, if I connect laptop via cord directly - it works with no problem, but when I connect it to PC via Asus router - no signal at all. What Should I do?
KnightRid
Re: HDMI to IPTV - Asus Router issue
Post by KnightRid » Tue Oct 04, 2016 4:43 am
try setting your router to allow ALL traffic through - DMZ mode - and see if that works. If not try a different cable or port on the router. if that still doesn't work then I am at a loss.
You paid that much to get your home theater feed to show on your PC? Ouch.
