Hi there,
I’m a newbie to online games. I noticed lags while playing online games.I have a good internet plan with a high bandwidth (http://www.thinktel.ca). I discussed with my friends and one of my friends suggested to use Iolo system mechanic. I didn’t notice any changes using the trial version.
My system configuration is http://pcpartpicker.com/list/KpL4gL. Anyhow, recently my PC completely frooze while playing online. Found some solutions online to try with the video card and no errors were reported when I did the memory test. I reinstalled the graphics drivers and updated windows 10 also. Still the issue is not resolved. Has anyone faced the same issue? Please, advice and share your ideas.
Thanks
Need help: Lag playing Online games
Re: Need help: Lag playing Online games
Ok, first question is what game? Do you have it in ALL games?
Make sure your video card is not overheating as even some brand new cards could have a faulty cooler. Multiple programs available like hwmonitor and gputemp.
Lower your graphics settings in the game to test if that is the problem. Lower them WAY down and try playing and see if you still have the problem.
Try the nvidia beta drivers.
I Also had the same problem before and in my case the solution was changing the windowed mode of the game (so I see what's happening while I game) to full screen mode.
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte B550 Aorus Elite, Ryzen 5800X @ stock, 32GB Patriot Viper DDR4 3200Mhz 16-18-18-36-1T, AMD RX 5700XT + AlphaCool WC, ACER Nitro XV2 27", SP 1TB nvme PCiE GEN3, Samsung 2TB; Cooler Master MW Gold 650W, Win10 Pro 64
- DJ Tucker
we would need to know the specs of your system, what games you are playing, what settings you are running each game and resolution in order to help you fully
MSI Z590 Gaming Edge Wifi
Corsair XR5 240mm x2 & 360mm
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
fatherviper
- Legit User
In some cases the latency of the connection will cause you to lag in live events.
AdrianG001
- Legit User
The lag is the case when the ping of the server doesn’t match with the ping of your connection or when your ping is higher than the servers’.”Ping” refers to the time used to make a connection of some internet service.It’s usually in rate of ‘ms’ and you can see the ping while joining the server-details.You can sometimes see your ping beside as well.Hitman wrote: ↑Mon Nov 07, 2016 11:59 pm Hi there,
Thanks
The ping also gets varied considering your CPU usage is high even though a there’s fine internet connectivity,as the flow of net is blocked to attain processes stability of the overall system.
All you can do is to check your ping and the servers’ and join when your ping is lower than the ping of the server.
Regards,
Adrian
