I have to say I was impressed with the fact this card can pull 190 watts on the power limit over the 168 watts on the ASUS. I can now remain at 2100mhz through out any benchmark I throw at it, compared to the ASUS with would thermal throttle and power limit to an average of 2015mhz and frequent drops to under 2000mhz.
During a full catzilla bench (raymarch test heats any gpu crazy hot), the stock thermal paste got the ASUS 1070 to 68c 100% fan and GC3 Extreme got it to 62c. Stock thermal paste got The Inno3D 1070 to 58c 100% fan and GC3 Extreme got it to 50c
The stock paste on the Inno3D 1070 was badly applied. In fact it was thick, all over the gpu and dried already. Cheap nasty stuff was clearly used in an attempt to save a few £££ hoping the water cooler would do it justice. A simple re-apply of thermal paste did amazing wonders. I did the test again with a little less paste (just in case I got a bad thermal reading) and got the following results: Inno3D 1070 GC3 Extreme got it to 48c.
As you can see that was the best I believe I could get. To make things better, I got it to pass it 2125/9200 @ 1.094v for 49c
I game at 1080p so the GTX 1070 is plenty for me
