Help! No LAN detected.
sbohdan
Post by sbohdan » Tue Sep 26, 2017 11:02 am
My son's PC doesn't show the ethernet card in device manager. First thought it was a driver problem, so uninstalled and installed a driver. Next I looked in BIOS but there is no LAN detected eighter. Than I bought a separate PCI ethernet card with a single LAN port. Still nothing. There is no yellow triangle in device manager just the whole "Network Adapters" category doesn't show. I'm out of ideas. Any help? ](*,)
There is Win7 Home on the PC.
Main rig: NZXT Phantom modded case with Danger Den WC, MSI Tomahawk B350, Ryzen 1700X @ 3.4Ghz, 16GB Patriot Viper DDR4 3200Mhz 16-18-18-36, MSI GTX 1060 3GT OC, Asus 24" 1ms 144hz, Intel P7600 256Gb nvme PCiE, Samsung 2TB; PC P&C 750W, Win10 Pro 64
bubba
Staff Writer
Staff Writer
Re: Help! No LAN detected.
Post by bubba » Tue Sep 26, 2017 2:03 pm
The on board may have shot craps. Boot to a linux live cd of some flavor a see if it will see the PCI card.
In the off chance if sees either of the NICs, Windows is dorked somehow. Sees nothing, could be the board.
-Thomas Jefferson
Post by Apoptosis » Tue Sep 26, 2017 3:04 pm
What is the board model number?
Updated to the latest BIOS/UEFI build?
So, you removed the driver and installed it. That means the NIC was there for the driver to install. Why its not seeing it after the driver is installed is weird. Can you go to a system restore point?
You might also want to run a program like CCleaner to tidy up the registry. That might do the trick.
When it doubt blow off the OS and do a fresh install!
KnightRid
Post by KnightRid » Wed Sep 27, 2017 5:17 am
Look in device manager for anything under OTHER DEVICES and it will say UNKNOWN or something similar. Remove it. Reboot. See if it installs a driver correctly.
Along with ccleaner also run malwarebytes or whatever spyware program you like the best.
Boot into safe mode with networking and see if you an find it or install it and get it to stick.
sbohdan
Post by sbohdan » Wed Sep 27, 2017 3:53 pm
Case solved. I took a spare, empty SSD and put a fresh install of Win7 on it. First it didn't work but than after one of the restarts, suddenly it did. I have no explanation why it did though. Made no sense. Anyway, Thanks for all the answers. It gave me couple of ideas. Just a bit confused why it didn't and than why it suddenly did :?
