Windows 10 password reset program
rxxus200
Legit Little One
Legit Little One
Post by rxxus200 » Wed Sep 27, 2017 7:47 pm
Ophcrack used to be my favorite option for password recovery. I recently upgraded my computer to win10 and found out the program is no longer working on it. Any alternative to Ophcrack? Freeware is preferred.
KnightRid
Re: Windows 10 password reset program
Post by KnightRid » Thu Sep 28, 2017 4:43 am
https://sysadminstricks.com/tricks/wind ... media.html
http://www.pcunlocker.com/reset-windows ... -disk.html
http://www.windowspasswordsreset.com/re ... -disk.html
Try the above, all should be the same but I guess it depends on your version of windows if you need to rename utilman or sethc
rxxus200
Legit Little One
Legit Little One
Post by rxxus200 » Thu Sep 28, 2017 7:49 pm
KnightRid wrote:https://sysadminstricks.com/tricks/wind ... media.html
https://www.tunesbro.com/reset-windows-10-password.html
Thanks for the help. Try 'net user' command. it seems not working. The computer still asks me for password after reset.
KnightRid
Post by KnightRid » Fri Sep 29, 2017 4:54 am
rxxus200 wrote:Thanks for the help. Try 'net user' command. it seems not working. The computer still asks me for password after reset.
You renamed and replaced the files specified after booting from the windows install disc?
I am looking for a free program to do it now but most cost now a days.
KnightRid
Post by KnightRid » Fri Sep 29, 2017 5:02 am
WOW, didnt think Offline NT would work any more - http://www.chntpw.com/download/ or one that has more on the disc - http://pogostick.net/~pnh/ntpasswd/bootdisk.html - but it does. I would use the original link as it is all you should need.
Encrypted files will be unreadable!!!!!! Most people do not have encrypted files anyway and if you would, you would have known to make a password reset disc.
rxxus200
Legit Little One
Legit Little One
Post by rxxus200 » Sat Sep 30, 2017 12:48 am
KnightRid wrote:WOW, didnt think Offline NT would work any more - http://www.chntpw.com/download/ or one that has more on the disc - http://pogostick.net/~pnh/ntpasswd/bootdisk.html - but it does. I would use the original link as it is all you should need.
Cool, thanks. I will give it a try.
