Win7 32 to 64?
Operating Systems
If its an OS, its here.
camaroguy1998
Re: Win7 32 to 64?
Post by camaroguy1998 » Wed Jan 24, 2018 8:10 pm
KnightRid wrote:SUCCESS!! Glad you got it man!!!
I guess I should tell you what the problem(s) were!
1. Pretty sure the 2 discs I used the first 2 times to install XP are corrupted in some way!
3rd disc was successful!
2. This being the big one, when I went in to bios to see if AHCI was enabled(it was not)
I read all the side notes when you highlight a category and there was a note that said under SATA enabled(instead of AHCI) use SATA ports 1-4 only! Ports beyond 4 can be enabled through the OS later! That I dont get, but its not a big deal.
Yes, I had the SSD connected to port 5! :oops:
After those changes it went fairly smooth!
Activation process sucked when I talked to an agent(for lack of a better word/name)
Yee Haa!
Hooray!
About damn time!
Anybody have 8GB(4x2gb) DDR2 800mhz they would like to donate?
ASUS BW-12B1ST BD Burners(X2)
EVGA 560ti SC
ASUS 27" LED LCD monitor
Corsair 600T case
camaroguy1998
Re: Win7 32 to 64?
Post by camaroguy1998 » Thu Feb 01, 2018 9:59 pm
I picked up 8gb of Kingston 800mhz for $45.
Runs pretty good for what it is!
Spent A LOT more time than money, but it works! :)
EVGA 560ti SC
Corsair 600T case
bubba
Staff Writer
Staff Writer
Re: Win7 32 to 64?
Post by bubba » Mon Feb 05, 2018 9:16 am
Now you have it all setup, image that drive and save it some where lol.
-Thomas Jefferson
camaroguy1998
Re: Win7 32 to 64?
Post by camaroguy1998 » Tue Feb 06, 2018 4:20 pm
bubba wrote:Now you have it all setup, image that drive and save it some where lol.
You got that right! I never want to do that again!
11 days of hell.
Back up, back up, back up!
EVGA 560ti SC
Corsair 600T case
smack323
Re: Win7 32 to 64?
Post by smack323 » Tue Feb 13, 2018 11:42 am
I see you got it working..Awesome. I was going to suggest installing Windows 10 64bit your Windows 7 key should work to install windows 10. Microsoft makes it pretty easy to create a Windows 10 install USB or DVD now- it will even work without getting activated so you can at least test out the system first.
Core i5-6500 - Corsair Vengence 16GB DDR4 2133 - Asus GTX 1070 DUAL 8GB - Antec 750W - Crucial 525GB SSD - Windows 10 64bit - ASUS 27" LED
camaroguy1998
Re: Win7 32 to 64?
Post by camaroguy1998 » Wed Feb 14, 2018 12:31 am
smack323 wrote:I see you got it working..Awesome. I was going to suggest installing Windows 10 64bit your Windows 7 key should work to install windows 10. Microsoft makes it pretty easy to create a Windows 10 install USB or DVD now- it will even work without getting activated so you can at least test out the system first.
I thought about 10, but the lack of drivers for my old hardware pretty much eliminated that option!
With 8gb memory($45) an older SSD(I had laying around) and Win7, it runs pretty good!
EVGA 560ti SC
Corsair 600T case
