AIDA64 Memory Usage at Idle
Kaos Kid
Post by Kaos Kid » Tue Feb 06, 2018 12:18 pm
How much memory does your AIDA64 program use at idle? By idle I mean not running any tests, just sitting there monitoring with the OSD on. I have noticed when it first starts up and OSD hits the screen that it is using around 90mb, but after a while I check in process manager and it is up around 400mb! Why is it using so much RAM for just monitoring? ZoneAlarm and Malwarebytes each use only 250>275mb each so why would AIDA64 be such a memory hog? I have the current update 5.95 stable...
DJ Tucker
Re: AIDA64 Memory Usage at Idle
Post by DJ Tucker » Tue Feb 06, 2018 6:42 pm
mine sits at 60mb while idle at the start and 90mb once I load up sensors. never anything above or below those usage.
Armageddon V1.0
Processor: Core i7 9700k 4.9Ghz (AVX 4.9Ghz) @ 1.264v Barrow 240mm+360mm
Memory: 16Gb Corsair Vengeance LED 2700Mhz 16-16-16-32-1T
Hard Drive: Silicon Power P32A80 128Gb & Intel 660p 2Tb
Video Card: RTX 2070 Heatkiller IV 2010Mhz @ 0.975v
Power Supply: Corsair HX1000i
Monitor: Lenovo L24Q-10 1440P
OS: Windows 10 64 bit Pro
Mobo: ASRock Z390 Phantom Gaming 6
Case: Vector VDM01
Peripherals: K70 Lux, M65 Pro, and Void Pro Wireless
