Looking into new water cooler!
camaroguy1998
Post by camaroguy1998 » Wed Feb 14, 2018 1:03 am
This is for my system in my sig!
The pump is starting to make a bit of noise from time to time!
Its creeping up on 4 yrs old with almost 24/7 run time.
Does anyone have a self contained H2O setup thats been reliable
and they would recommend as a pretty much direct replacement for a factory AMD 9590 setup?
120mm
ASUS BW-12B1ST BD Burners(X2)
EVGA 560ti SC
ASUS 27" LED LCD monitor
Corsair 600T case
EVGA 560ti SC
Corsair 600T case
KnightRid
Re: Looking into new water cooler!
Post by KnightRid » Wed Feb 14, 2018 4:55 am
I have a Thermaltake Water 2.0 on my old core i7-3770K and it has been rock solid for all these years. Recently started having a bit of trouble with one of the fans not wanting to get going but kicking it to high speed and then back down makes it purr along (kind of like me as I get older lol). The 3.0 is out and has a 3 year warranty I believe so pretty decent in my book!
Anyway i would say to look at Thermaltake or even another CoolerMaster since yours has done so well.
DJ Tucker
Post by DJ Tucker » Wed Feb 14, 2018 4:09 pm
I have the Lepa Exllusion 240 and it is a great cooler. Got it about 3 months after release and still going at full speed. I have only used mine for 4-6 hours a day with pump at 100%/4000rpm 25% above its rated max speed. Even Enermax have said its rare for a pump to far exceed its rated speed but not uncommon to exceed its rated speed within 10%. Still, I'm am one of few that got lucky. got my i7 2600k (5ghz 1.416v) running 65c at 100% load on occt linpack after 30mins testing.
Best cooler I have used even though I recently tested a Corsair h150i and Thermaltake water 3.0. Both were great coolers but got my 2600k to 70c(Corsair h150i) and 68c (Thermaltake Water 3.0) and 65c (Lepa Exllusion 240) which all three hit after 10mins and remained at for another 20mins before ending the test. This was done with Thermal Grizzly Kryonaut. Surprised the h150i and Water 3.0 didn't beat the Exllusion.
The only set back of the Lepa is the price but the £100 I paid over here proved best cost/performance as the h150i is £150 and Water 3.0 £120 in the UK. Get what ever Corsair or Thermaltake or Lepa you can reasonably afford. All will cooler fantastically but Lepa wins me over surprisingly.
9600kf 4.8ghz (1.216v)|Z390 Asrock Phantom Gaming 6|16gb DDR4 Corsair Vengeance 2666mhz|RTX 2070 1950mhz (0.900v)|Corsair HX1000i|128gb Silicon Power NVME (OS)|2tb WD Blue M.2 SSD (Games)|Aqua Computer D5 Next Pump|Alphacool Eisblock XPX Aurora CPU Block|Watercool Heatkiller IV GPU Block|360+240mm Radiators|Vector VDM01
royden
Legit User
Legit User
Post by royden » Wed Oct 03, 2018 1:26 am
The Thermaltake Water 3.0 is a good option also.
camaroguy1998
Post by camaroguy1998 » Fri Nov 02, 2018 1:28 pm
I'm thinking this will make a nice replacement for my ailing CoolerMaster!
https://forums.legitreviews.com/viewtop ... 11&t=46802
I guess the side panel may not make it back on! Corsair 600T has no window! :(
Hmmm, maybe it's time for a new case!?!
EVGA 560ti SC
Corsair 600T case
bubba
Staff Writer
Staff Writer
Post by bubba » Sun Nov 04, 2018 11:07 am
friends help friends say no to RGB
-Thomas Jefferson
camaroguy1998
Post by camaroguy1998 » Sun Nov 04, 2018 10:33 pm
bubba wrote:friends help friends say no to RGB
LOL!
For me, its more for the cooling performance than the RGB!
The RGB is just an added bonus!
Already been bit by the LED bug! lol
Not sure if this will work!?!
https://scontent-ort2-2.xx.fbcdn.net/v/ ... e=5C8261A6
EVGA 560ti SC
Corsair 600T case
bubba
Staff Writer
Staff Writer
Post by bubba » Mon Nov 05, 2018 7:32 am
my rig sets 2 feet from my head when I sleep. I blacked out any LED I could find on my system. Helps for the nights I leave the thing running to crunch on downloads (DSL Sucks) or trans-coding.
-Thomas Jefferson
camaroguy1998
Post by camaroguy1998 » Tue Aug 06, 2019 10:16 pm
Its been 9 months and the setup is fine!
The noise wound up being the rear fan on the radiator!
I replaced it with a cheap 120mm fan I had laying around and so far no noises or big issues!
My temps are running about 3 to 5C warmer but still in a good range!
Yeah yeah, I should've posted this a couple months ago when I figured it out!
EVGA 560ti SC
Corsair 600T case
DJ Tucker
Post by DJ Tucker » Wed Aug 07, 2019 7:13 am
glad you got it all working again albeit a little warmer :)
camaroguy1998
Post by camaroguy1998 » Wed Aug 21, 2019 10:07 pm
True to form....When you have a matched pair(of anything) they should be replaced at the same time! :oops:
Monday nite my electric flickered and then on Tuesday afternoon it went off for 3 or 4mins.
Apparently when the electric came on the fan I did not replace DID NOT!(at that moment unknown to me)
I started it back up and it ran for about 5 mins then shut down!
When it finally cooled down enough to start up again I noticed the fan wasnt running!
So, now it has 2 new Matching cheapo fans! Guess its time to shop for some nice ones!
EVGA 560ti SC
Corsair 600T case
DJ Tucker
Post by DJ Tucker » Thu Aug 22, 2019 5:00 am
that's the issue with cheap fans they work so long as power is constant and no fluctuations.
camaroguy1998
Post by camaroguy1998 » Fri May 01, 2020 1:49 am
Sooo, Here I am again!
Its been a while and the cooler has been doing ok, at least until recently!
I noticed a couple times after watching a few videos and general web surfing,
my temps were in the 45c to 48c range. Which seemed a bit high to me!
Yesterday(wed) I ran a program that uses the CPU at 100%.
That did not go so well! About 3 minutes in it was hitting 70c and locked up before it hit 5 minutes!
I used to be able to run the program and never go over 60c!
Right now it idles around 32c and while I'm typing this its sitting on 41c at less than 10% load!
So i'm revisiting the AIO water cooler replacement!
Its been a while, so I'm wondering if there's anything new out there?
I did a little looking and a lot of the choices I was looking at last year are Old News!
Some are not even in stock at Newegg or Amazon!
My options are limited by the case to a single 120mm or a 240mm steup!
I really think the 240 is the only route to go!
The AMD 9590 is heat monster!
EDIT: Looking at this, any opinions?
https://www.newegg.com/corsair-icue-h10 ... 6383558656
EVGA 560ti SC
Corsair 600T case
DJ Tucker
Post by DJ Tucker » Fri May 01, 2020 3:47 pm
you just found your new aio. that is a good cooler for your cpu. should keep temps very nice and cool.
camaroguy1998
Post by camaroguy1998 » Fri May 01, 2020 10:26 pm
I agree and priced right!
I expected $150 to $175...$119.99 was a good selling point!
Ordered today! :)
EVGA 560ti SC
Corsair 600T case
DJ Tucker
Post by DJ Tucker » Sat May 02, 2020 12:59 pm
Ordered today! :)
Good man. Let us know what the temps are. Do a temp test with current cooler then with the aio on the same day for a fair comparison :)
