Esoteric way a GA-790XTA-UD4 runs an FX?
Discussion about AMD CPU Motherboards
Mac29
Legit Little One
Legit Little One
Post by Mac29 » Tue Mar 20, 2018 10:17 am
Been reading about AM3b and black cpu blocks, bios updates from mobo manufacturers. Anyone w/real knowledge know if Gigabyte GA-790XTA-UD4 had a bios update that would make an FX cpu work? I presume the pins won't match so no, but just want to check. (The GB site is ridiculous
w/registering: enter email & a password then to login wants a username but won't accept email. Weird.)
Thanks,
Mac
KnightRid
Re: Esoteric way a GA-790XTA-UD4 runs an FX?
Post by KnightRid » Wed Mar 21, 2018 4:11 am
From what I have read, you are right, the answer is no. Just wont fit.
Would be nice if they would make new blocks that would match the pins up for motherboards so you could change chips and keep your MB but that would take money out of their pockets ;)
