New system
Re: New system
Post by Apoptosis » Mon Nov 05, 2018 10:06 am
Not trying to be a dick...
Have you counted standoffs and made sure there is a screw used for each? Some cases have standoffs in locations not drilled out on the board.
Also, I'm offering again to send you out a brand new board in the box if you'd like to try a second board.
KnightRid
Re: New system
Post by KnightRid » Tue Nov 06, 2018 4:44 am
Apoptosis wrote:Not trying to be a dick...
LOL - yea, I thought of the standoff thing too and counted 3 times to make sure. I was thinking there was one in there that should not be and was making contact but there wasn't.
Hate for you to do the shipping thing again (time and money) if I can get this working. It worked for quite a while this last time compared to how it was doing so maybe with cleaning the cpu real good and reapplying paste will do the trick.
Gonna get into bios and mess around oc'ing a bit today hopefully so I can really put this through the paces and see if it acts up.
camaroguy1998
Re: New system
Post by camaroguy1998 » Tue Nov 06, 2018 4:55 am
Put a piece of electrical tape over each standoff. Then install board.
ASUS BW-12B1ST BD Burners(X2)
EVGA 560ti SC
ASUS 27" LED LCD monitor
Corsair 600T case
KnightRid
Re: New system
Post by KnightRid » Tue Nov 06, 2018 7:52 am
camaroguy1998 wrote:Put a piece of electrical tape over each standoff. Then install board.
I put the paper/cardboard washers on each of them last time I pulled it apart just to make sure they were not touching :)
I am still getting the odd temp readings also
From previous post
Just took this reading now
Would anyone have a reasoning for this? seems 1,4 and 5 are always way hotter while 2 is way cooler. Even when stress testing they never equal out.
Re: New system
Post by Apoptosis » Tue Nov 06, 2018 9:42 am
Do you know what those are even measuring? Those look like random board temperature points. Likely VRM or something. Might want to e-mail Gigabyte with a full report from the application and ask what the temperature readings are actually measuring.
That board has "Smart Fan 5 features 5 Temperature Sensors"... Maybe the Gigabyte application or BIOS temperature menu will explain what those are?
Same board here and its showing what the temperatures are for. Also people explaining why the readings highlighted aren't the same - https://www.reddit.com/r/GAAB350/commen ... _readings/
KnightRid
Re: New system
Post by KnightRid » Tue Nov 06, 2018 10:18 am
So it died. Kinda lol might be the main power connector as it would not turn on and when I went to remove the power cable the lights flickered. I give up as I dont think I can replace that with my non existant soldering skills :)
Sent from my SM-G950U using Tapatalk
Re: New system
Post by Apoptosis » Tue Nov 06, 2018 12:27 pm
send me an e-mail or give me a call.
DJ Tucker
Re: New system
Post by DJ Tucker » Fri Nov 09, 2018 4:06 am
This year really hasn't gone well many of us. Even I had bad luck when 1803 update came out for windows 10 and refused to install then corrupt my current install. Took 5 days to get windows working from clean install and only just got it up again :( As for the mobo or power supply (psu most likely by the sound of it) dying on you after all the issues, I would have almost given up by now. I'll give you credit where credit is due for your fighting spirit 8)
9600kf 4.8ghz (1.216v)|Z390 Asrock Phantom Gaming 6|16gb DDR4 Corsair Vengeance 2666mhz|RTX 2070 1950mhz (0.900v)|Corsair HX1000i|128gb Silicon Power NVME (OS)|2tb WD Blue M.2 SSD (Games)|Aqua Computer D5 Next Pump|Alphacool Eisblock XPX Aurora CPU Block|Watercool Heatkiller IV GPU Block|360+240mm Radiators|Vector VDM01
KnightRid
Re: New system
Post by KnightRid » Fri Nov 09, 2018 5:30 am
DJ Tucker wrote: As for the mobo or power supply (psu most likely by the sound of it) dying on you after all the issues, I would have almost given up by now. I'll give you credit where credit is due for your fighting spirit 8)
Tried 2 different PSU's and both do the same thing. Oh I checked and rechecked everything i could think of!!
2018 has seen our car totally die that we put thousands of dollars into and we had to buy a new one, multiple hospital visits for her dad, wife was in twice, me with my neck, Every little thing breaking at some point that we had to shell out money for (waiting for this laptop to go since it is still 2018 and luck sucks this year), tried to go on vacation and had to evacuate after 3 days because of the hurricane (never even hit in Chincoteague, VA where we go), went back in October to finish out our stay (very nice of them to allow us back down) and the day we go down guess what comes across the country, yep, hurricane and it turned wet and cold *sigh* it has REALLY been a shitty year. Bright spot is having new computer stuff to play with, no matter the problems it is still way better than everything else. :supz:
DJ Tucker
Re: New system
Post by DJ Tucker » Fri Nov 09, 2018 6:44 pm
I love how the computer even though its seen better days and giving you the grief it is, is still the highlight of 2018 for you :lol:
KnightRid
Re: New system
Post by KnightRid » Sat Nov 10, 2018 4:26 am
DJ Tucker wrote:I love how the computer even though its seen better days and giving you the grief it is, is still the highlight of 2018 for you :lol:
That is how I earn my nerdy geek card LOL
KnightRid
Re: New system
Post by KnightRid » Thu Dec 20, 2018 8:08 am
Sorry, so much going on I forgot to update you all. I know you are checking this thread every other minute to see what the hell is going on :mrgreen:
Problem is the hold down thumb screws/pegs for the water cooler is shaving off metal particles when you turn the thunb screws! So weird but that was what was causing the problem.
I am going to try and replace the hold down stuff as soon as I have some time to really search around for them or even look at a local hardware store for something that would work. My best bet would be to email the company and fond out if they sell replacements that do not shave metal off of them. It is sad that it had to ruin a good motherboard and an old gtx660 video card :(
I am back up and running again (thanx a ton to Nate and my use of a credit card to get a MSI Radeon RX580) so I am still in the leery/testing phase to make sure I blew all the metal particles off and to make sure everything works good for a few weeks before I even attempt to overclock again.
camaroguy1998
Re: New system
Post by camaroguy1998 » Thu Dec 20, 2018 2:38 pm
At least you figured it out! That's great!
It sucks when those things happen, that just don't happen to anyone else! ](*,)
EVGA 560ti SC
Corsair 600T case
DJ Tucker
Re: New system
Post by DJ Tucker » Sun Dec 23, 2018 2:19 pm
good job on finding the issue. Nate to the rescue 8) it's the most unexpected issue that happens to you hey knightrid :shock:
KnightRid
Re: New system
Post by KnightRid » Mon Dec 24, 2018 4:22 am
I should write a book LOL
DJ Tucker
Re: New system
Post by DJ Tucker » Mon Dec 24, 2018 5:32 am
should call the book the unexpected moments of Knightrid.
Re: New system
Post by Apoptosis » Wed Dec 26, 2018 2:17 pm
Over 20 years building PCs and I've never seen metal shavings like that from a water cooler thumb screw... Unreal.
Glad it's back up and running.
Re: New system
Post by Apoptosis » Wed Feb 13, 2019 3:29 pm
Still good?
sbohdan
Re: New system
Post by sbohdan » Tue Feb 19, 2019 7:14 am
KnightRid wrote:
Fri Sep 14, 2018 9:05 am
So it happened again with the windows update that came through. Computer locked up, power button would not shut it off and then it would not restart. I moved the cooler block around a bit (pushed in on it really) and then it booted up but the led is back to just red.
I want to pull the water block off and see if the cpu comes out with it. I have read online that people had that issue with some boards/waterblocks and since the last time I took it off the CPU came out before I released the locking lever, it may be the problem.
This is why I have windows updates turned off for the last 6 years. No problems whatsoever. I believe their "security updates" are only designed to upgrade how they can spy on us more efficiently. I also hated when updates were always running at the worst time to slow down the PC. No "updates" for me.
Main rig: NZXT Phantom modded case with Danger Den WC, MSI Tomahawk B350, Ryzen 1700X @ 3.4Ghz, 16GB Patriot Viper DDR4 3200Mhz 16-18-18-36, MSI GTX 1060 3GT OC, Asus 24" 1ms 144hz, Intel P7600 256Gb nvme PCiE, Samsung 2TB; PC P&C 750W, Win10 Pro 64
Laptop: Dell XPS 1530 (T9500; 4GB 800 RAM; 120GB Crucial SSD; 8600GT; WIN10 pro 64bit)
KnightRid
Re: New system
Post by KnightRid » Wed Feb 20, 2019 5:35 am
Sorry, been busy with the estate stuff.
Working great except the lights. Installed the updated Fusion program and now no lights come on. I am going to uninstall it and try setting a color in bios again to see if it fixes it but no shut offs or anything crazy going on but that.
