Official F@H GPU Work Unit Thread
- Apoptosis
- Site Admin
If and when any of you finish a GPU WU post it up in there.... We would love to see how long it took and what work unit it was!
- Apoptosis
- Site Admin
For Project 2719 it took roughly 6 minutes[13:47:20] Project: 2719 (Run 0, Clone 135, Gen 1)
[13:47:20]
[13:47:20] Assembly optimizations on if available.
[13:47:20] Entering M.D.
[13:47:27] Completed 0
[13:47:27] Starting GUI Server
[13:47:34] Completed 1
[13:47:37] Completed 2
[13:47:41] Completed 3
[13:47:45] Completed 4
[13:47:49] Completed 5
[13:47:53] Completed 6
[13:47:56] Completed 7
[13:48:00] Completed 8
[13:48:04] Completed 9
[13:48:08] Completed 10
[13:53:15] Completed 90
[13:53:18] Completed 91
[13:53:22] Completed 92
[13:53:26] Completed 93
[13:53:30] Completed 94
[13:53:34] Completed 95
[13:53:37] Completed 96
[13:53:41] Completed 97
[13:53:45] Completed 98
[13:53:49] Completed 99
[13:53:53] Completed 100
[13:54:53]
[13:54:53] Finished Work Unit:
[13:54:53] - Reading up to 45408 from "work/wudata_06.trr": Read 45408
[13:54:53] - Reading up to 24184 from "work/wudata_06.xtc": Read 24184
[13:54:53] logfile size: 10673
[13:54:53] Leaving Run
[13:54:55] - Writing 81337 bytes of core data to disk...
[13:54:55] Done: 80825 -> 74454 (compressed to 92.1 percent)
[13:54:55] ... Done.
[13:54:55] - Shutting down core
[13:54:55]
[13:54:55] Folding@home Core Shutdown: FINISHED_UNIT
Project 1808 (Amber) took me 18 hours over 3 days to finish and gave me 158 credits :)[20:30:59] Working on Unit 06 [October 5 20:30:59]
[20:30:59] Project: 1808 (Run 10, Clone 673, Gen 55)
[20:31:06] Completed 0 out of 500000 steps (0)
[20:51:19] Completed 5000 out of 500000 steps (1)
[21:11:49] Completed 10000 out of 500000 steps (2)
[11:25:15] Working on Unit 06 [October 6 11:25:15]
[16:01:34] Working on Unit 06 [October 7 16:01:34]
[19:44:04] Completed 490000 out of 500000 steps (98)
[19:58:33] Completed 495000 out of 500000 steps (99)
[20:12:38] Completed 500000 out of 500000 steps (100)
[20:13:38]
[20:13:38] Finished Work Unit:
[20:13:39] Leaving Run
[20:13:39] - Writing 414944 bytes of core data to disk...
[20:13:39] ... Done.
[20:13:39] - Shutting down core
[20:13:39]
[20:13:39] Folding@home Core Shutdown: FINISHED_UNIT
Edit: it actually took 28 hours lol
- Jeff_Grant
- Legit User
Sapphire x1600 Pro 256 AGP 8x[16:52:30] Folding@Home GPU Core - Beta
[16:52:30] Version 0.06 (Tue Oct 3 07:59:02 PDT 2006)
[16:52:30]
[16:52:30] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler
Version 13.10.3077 for 80x86
[16:52:30] Build host: CYGWIN_NT-5.1 vishal-gpu 1.5.19(0.150/4/2)
2006-01-20 13:28 i686 Cygwin
[16:52:30] Preparing to commence simulation
[16:52:30] - Looking at optimizations...
[16:52:30] - Created dyn
[16:52:30] - Files status OK
[16:52:30] - Expanded 82115 -> 443705 (decompressed 540.3 percent)
[16:52:30]
[16:52:30] Project: 2711 (Run 1, Clone 72, Gen 0)
[16:52:30]
[16:52:30] Assembly optimizations on if available.
[16:52:30] Entering M.D.
[16:52:45] Completed 0
[16:52:45] Starting GUI Server
[17:14:07] Completed 1
[17:35:26] Completed 2
[17:56:47] Completed 3
[18:18:07] Completed 4
[18:39:27] Completed 5
[19:00:48] Completed 6
[19:22:09] Completed 7
[19:43:29] Completed 8
[20:04:51] Completed 9
[20:26:13] Completed 10
[20:47:34] Completed 11
[21:08:55] Completed 12
[21:30:17] Completed 13
[21:51:37] Completed 14
[22:12:59] Completed 15
[22:34:18] Completed 16
[22:55:38] Completed 17
[23:16:58] Completed 18
[23:38:21] Completed 19
[23:59:41] Completed 20
[00:21:04] Completed 21
[00:42:24] Completed 22
[01:03:46] Completed 23
[01:25:04] Completed 24
[01:46:25] Completed 25
[02:07:46] Completed 26
[02:29:08] Completed 27
[02:50:28] Completed 28
[03:11:50] Completed 29
[03:33:09] Completed 30
[03:54:30] Completed 31
[04:15:49] Completed 32
[04:37:12] Completed 33
[04:58:40] Completed 34
[05:20:00] Completed 35
[05:41:21] Completed 36
[06:02:41] Completed 37
[06:24:01] Completed 38
[06:45:20] Completed 39
[07:06:42] Completed 40
[07:28:02] Completed 41
[07:49:23] Completed 42
[08:10:44] Completed 43
[08:32:05] Completed 44
[08:53:25] Completed 45
[09:14:46] Completed 46
[09:36:06] Completed 47
[09:57:27] Completed 48
[10:18:48] Completed 49
[10:40:10] Completed 50
[11:01:29] Completed 51
[11:22:50] Completed 52
[11:44:10] Completed 53
[12:05:41] Completed 54
[12:27:02] Completed 55
[12:48:24] Completed 56
[13:09:44] Completed 57
[13:31:07] Completed 58
[13:52:28] Completed 59
[14:13:51] Completed 60
[14:35:12] Completed 61
OC 580 core 432 (864) mem.
60C core with 22C ambient room
~21.22 frame times w2711WU
PM Banias 1.6ghz @ 1.85ghz with a CT479 adapter.
1G DDR333
Total watts at the wall is 120W.
- dicecca112
- Site Admin
post here, they will tell you wants up. Or email me your logs, and I'll post under my username
http://forum.folding-community.org/
- kenc51
I might have found the problem, when I checked my config the following option was enabled "Minimize networking -- get and submit work in batches (no/yes)"
It looks like it's storing finished WU's and submitting in batches.........not much use for a beta client IMO.
I'll run it for one more night and see how it goes!
- dicecca112
- Site Admin
- kenc51
Not to worry, I'm sure that was the problem, also if I enabled "use IE settings" I wouldn't be able to download a new WU either!dicecca112 wrote:make sure use IE settings is set to NO as well, if you have IE7, also make sure you have the most recent client, there was update last week i think. There is a link on the page that I linked to above
- Jeff_Grant
- Legit User
According to Stanford, the nvidia 7X00 series GPU's ran the folding code too slowly to be worth while, but I was wondering if anyone has tested it. I would think since they've had it running before it should work fine. The only problem is the part of the code that checks out which card you have running. The software checks which card you have (I think, certainly not positive about this) by looking at the windows registry key for the driver. If it says x1600, x1650, x1800, x1900 or x1950, the program runs. If not, it halts. I wonder if changing this registry entry would allow the cards fold. Would be interesting to try. Right now I have an x1600 and an x1900GT, no 7x00s to test, but I'm sure they're are tons out there that might want to give it a go.
The reason I think this might work is because installing the driver manually for some ATI cards that aren't supported (x1300s for example) with an x1600 driver allow them to fold okay.
- Jeff_Grant
- Legit User
Re: Official F@H GPU Work Unit Thread
I later found out from mhouston that the 7x00 series GPUs had limited registers, and the looping/branching wasn't robust enough to handle the latest GPU code they wanted to run.
http://forum.folding-community.org/ftop ... c-120.html
"We started originally on NV4X hardware. The hardware was slow because of register pressure and looping issues. When we got X1K boards, looping had fewer restrictions and we didn't have performance cliffs with registers. So development has continued down that path which makes things no longer work on boards before G8X on Nvidia's side without a large rewrite and even then, performance is extremely poor compared to X1K hardware. G80 *should* work with the current code setup, we are just hunting bugs through the shader compilers and code setup."
-mhouston
Big thanks to Mike for the answers.
-mhouston
- Jeff_Grant
- Legit User
The 2600's may not be the best gaming GPU's out there even for those on a budget, but I do hope they're good folders. Legit, no reviews yet on the 2600 cards? Any reason why the hold out?
Um, my general purpose computer has an X1900XT and I'd like to try using that to fold. Do I need to download a special version of the client? or will one of the regular clients work?
Please Advise! (Thanks in advance!)
Edit: I apologize profusely!! I should have just gone and looked before asking... (download complete - I will now attempt an install...)
Intel Core i7 4820K @ 4 GHz | Asus Rampage IV Formula | 16GB Patriot DDR3-1866 | Asus Poseidon GTX 780 water cooled... (other stuff too <- 500 char limit!)
This is with a Sapphire X900XT/256. However, I just realized that it may be running this with the standard "non-3D" clocks - so that's 500MHz core and 600MHz memory. Also I just remembered that I haven't updated my video drivers on this system in a couple of months.[02:59:55] *------------------------------*
[02:59:55] Folding@Home GPU Core - Beta
[02:59:55] Version 0.10 (Mon Oct 30 12:32:17 PST 2006)
[02:59:55]
[02:59:55] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 13.10.3077 for 80x86
[02:59:55] Build host: CYGWIN_NT-5.1 vishal-gpu 1.5.19(0.150/4/2) 2006-01-20 13:28 i686 Cygwin
[02:59:55] Preparing to commence simulation
[02:59:55] - Looking at optimizations...
[02:59:55] - Created dyn
[02:59:55] - Files status OK
[02:59:55] - Expanded 86975 -> 443705 (decompressed 510.1 percent)
[02:59:55]
[02:59:55] Project: 2725 (Run 6, Clone 568, Gen 1)
[02:59:55]
[02:59:55] Assembly optimizations on if available.
[02:59:55] Entering M.D.
[03:00:02] Working on Protein
[03:00:02] Starting GUI Server
[03:10:48] Completed 1
[03:21:23] Completed 2
[03:31:58] Completed 3
[03:42:33] Completed 4
[03:53:08] Completed 5
[04:03:43] Completed 6
[04:14:17] Completed 7
[04:24:52] Completed 8
[04:35:27] Completed 9
[04:46:02] Completed 10
[04:56:37] Completed 11
[05:07:12] Completed 12
[05:17:47] Completed 13
[05:28:22] Completed 14
[05:38:57] Completed 15
[05:49:32] Completed 16
[06:00:06] Completed 17
[06:10:41] Completed 18
[06:21:16] Completed 19
[06:31:51] Completed 20
[06:42:26] Completed 21
[06:53:01] Completed 22
[07:03:35] Completed 23
[07:14:10] Completed 24
[07:24:45] Completed 25
[07:35:20] Completed 26
[07:45:55] Completed 27
[07:56:30] Completed 28
[08:07:04] Completed 29
[08:17:39] Completed 30
[08:28:14] Completed 31
[08:38:49] Completed 32
[08:49:24] Completed 33
[08:59:44] + Working...
[08:59:58] Completed 34
[09:10:33] Completed 35
[09:21:08] Completed 36
[09:31:42] Completed 37
[09:42:17] Completed 38
[09:52:52] Completed 39
[10:03:27] Completed 40
[10:14:02] Completed 41
[10:24:36] Completed 42
[10:35:11] Completed 43
[10:45:46] Completed 44
[10:56:21] Completed 45
[11:06:56] Completed 46
[11:17:31] Completed 47
[11:28:06] Completed 48
[11:38:41] Completed 49
[11:49:16] Completed 50
[11:59:51] Completed 51
[12:10:26] Completed 52
[12:21:00] Completed 53
[12:31:35] Completed 54
[12:42:10] Completed 55
[12:52:45] Completed 56
[13:03:20] Completed 57
[13:13:55] Completed 58
[13:24:29] Completed 59
[13:35:04] Completed 60
[13:45:39] Completed 61
[13:56:14] Completed 62
[14:06:49] Completed 63
[14:17:24] Completed 64
[14:27:59] Completed 65
[14:38:33] Completed 66
[14:49:07] Completed 67
[14:59:42] Completed 68
[14:59:45] + Working...
[15:10:17] Completed 69
[15:20:52] Completed 70
[15:31:26] Completed 71
[15:42:05] Completed 72
[15:52:46] Completed 73
[16:03:26] Completed 74
[16:14:07] Completed 75
[16:24:48] Completed 76
[16:35:28] Completed 77
[16:46:09] Completed 78
[16:56:49] Completed 79
[17:07:30] Completed 80
[17:18:10] Completed 81
[17:28:51] Completed 82
[17:39:31] Completed 83
[17:50:12] Completed 84
[18:00:53] Completed 85
[18:11:33] Completed 86
[18:22:14] Completed 87
[18:32:54] Completed 88
[18:43:35] Completed 89
[18:54:10] Completed 90
[19:04:45] Completed 91
[19:15:20] Completed 92
[19:25:55] Completed 93
[19:36:30] Completed 94
[19:47:04] Completed 95
[19:57:40] Completed 96
[20:08:14] Completed 97
[20:18:49] Completed 98
[20:29:24] Completed 99
[20:40:59]
[20:40:59] Finished Work Unit:
[20:40:59] - Reading up to 45408 from "work/wudata_01.trr": Read 45408
[20:40:59] - Reading up to 969032 from "work/wudata_01.xtc": Read 969032
[20:40:59] logfile size: 34638
[20:40:59] Leaving Run
[20:41:00] - Writing 1050150 bytes of core data to disk...
[20:41:00] Done: 1049638 -> 1014746 (compressed to 96.6 percent)
[20:41:00] ... Done.
[20:41:00] - Shutting down core
[20:41:00]
[20:41:00] Folding@home Core Shutdown: FINISHED_UNIT
[20:41:04] CoreStatus = 64 (100)
[20:41:04] Sending work to server
I could overclock this card if I reinstalled my Koolance water cooling kit. Otherwise the confines of the case make that impractical for long term use. Would overclocking the card help significantly with folding?
- Jeff_Grant
- Legit User
Fired up a 3850 and 2600XT with the new GPU2 client and it's working great, and making good point production. Has anyone else started using this client?
- DaIceMan
E6400 @ 3.2 (8x400), 4gb ram, 8800GTX (630/1050).[05:28:00] Project: 5002 (Run 8, Clone 186, Gen 34)
[05:28:00]
[05:28:00] Assembly optimizations on if available.
[05:28:00] Entering M.D.
[05:28:07] Working on p5002_supervillin_e1
[05:28:07] Client config found, loading data.
[05:28:07] Starting GUI Server
[05:28:24] Completed 1%
[05:28:41] Completed 2%
[05:28:58] Completed 3%
[05:29:16] Completed 4%
[05:29:33] Completed 5%
[05:29:50] Completed 6%
[05:30:07] Completed 7%
[05:30:24] Completed 8%
[05:30:41] Completed 9%
[05:30:59] Completed 10%
[05:53:50] Completed 90%
[05:54:07] Completed 91%
[05:54:25] Completed 92%
[05:54:42] Completed 93%
[05:54:59] Completed 94%
[05:55:16] Completed 95%
[05:55:33] Completed 96%
[05:55:50] Completed 97%
[05:56:07] Completed 98%
[05:56:25] Completed 99%
[05:56:42] Completed 100%
[05:57:42]
[05:57:42] Finished Work Unit:
[05:57:42] - Reading up to 1441080 from "work/wudata_06.trr": Read 1441080
[05:57:42] trr file hash check passed.
[05:57:42] - Reading up to 452672 from "work/wudata_06.xtc": Read 452672
[05:57:42] xtc file hash check passed.
[05:57:42] edr file hash check passed.
[05:57:42] logfile size: 58262
[05:57:42] Leaving Run
[05:57:45] - Writing 1953086 bytes of core data to disk...
[05:57:45] Done: 1952574 -> 1784229 (compressed to 91.3 percent)
[05:57:45] ... Done.
[05:57:45] - Shutting down core
[05:57:45]
[05:57:45] Folding@home Core Shutdown: FINISHED_UNIT
Same work unit on a buddies E8400 stock, 4gb ram, 9600GT is running right at 31s per step.
